[gdal-dev] Writing concurrent indexes to a FileGDB
Even Rouault even.rouault at spatialys.com
Mon Feb 6 04:01:20 PST 2023
Tim,
Currently there is no guarantee that concurrent updates to the same
FileGDB database, either from the same process or from different
process, are safe, as no locks are set, and the driver might cache in
memory things assuming that nothing else changes them behind its back.
That said, I *believe* (but definitely doesn't guarantee) that you could
create indexes on different layers/tables of a FileGDB from concurrent
ogrinfo instances. It is probably not safe however to create indexes on
different columns of the same table concurrently, because the
.gdbindexes file might be written concurrently
Even
Le 06/02/2023 à 12:03, Tim Martin via gdal-dev a écrit :
> Hi GDAL Devs
> I posted this question on GIS Stack Exchange and someone recommended I
> contact this group
> (https://gis.stackexchange.com/questions/451331/adding-multiple-attribute-indexes-to-filegdb-using-ogrinfo/451336#451336)
> I have the unfortunate task of creating some very large FileGDB and
> need to add multiple indexes to several attributes on each Feature Type.
> I saw that the OpenFileGDB driver under Dev is now able to Write, so
> am using that version, which by my testing is 3 or 4 times faster than
> the original FielGDB driver – which is amazing!!!
> Now I need to index these columns and it has taken 26hrs to add 5
> attribute indexes due to the sheer number of features (200mill or so).
> So am wondering if there is a way to use ogrinfo and write indexes
> concurrently?
> With thanks Tim
> This email and any attachments are intended only for the intended
> recipient and may contain sensitive information. If you are not the
> intended recipient, please immediately delete this email and inform
> the sender.
> OS email communications may be monitored to ensure the secure and
> effective operation of our systems and for other lawful purposes.
> Subject to contract: No rights are to be derived from any proposal
> contained in this email until a written agreement containing all
> necessary terms is executed between the relevant parties.
> Thank you for your cooperation.
> Ordnance Survey Limited (Company Registration number 09121572)
> Registered Office: Explorer House
> Adanac Drive
> Southampton SO16 0AS
> Tel: 03456 050505
> http://www.os.uk
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230206/b15c1f6f/attachment.htm>
