[gdal-dev] GML driver - gfs geometry type values and supported GML geometry types
Johannes Echterhoff
echterhoff at interactive-instruments.de
Thu Jan 5 22:05:31 PST 2023
Even,
Thank you so much for providing the right place in the source code with the relevant information about OGR-to-QGIS geometry type mappings! I’ll document that in my mapping instructions.
Best regards,
Johannes
Von: Even Rouault <even.rouault at spatialys.com>
Gesendet: Donnerstag, 5. Januar 2023 22:50
An: Johannes Echterhoff <echterhoff at interactive-instruments.de>; gdal-dev at lists.osgeo.org
Betreff: Re: AW: [gdal-dev] GML driver - gfs geometry type values and supported GML geometry types
The possible reason, that this may be due to a lack of mapping between OGR and QGIS geometry types, is quite intriguing. I tried to find out more on the web, and came across https://github.com/qgis/QGIS/blob/master/src/core/providers/ogr/qgsogrprovider.cpp (if that is the right place to look for the actual code),
==> https://github.com/qgis/QGIS/blob/389a8edc721693baa8070fbce8b8488fcc7a7e8c/src/core/providers/ogr/qgsogrproviderutils.cpp#L1935
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230106/53dd85a6/attachment.htm>
