[gdal-dev] How to extract field domains from a gdb
Even Rouault
even.rouault at spatialys.com
Tue Jan 17 07:39:53 PST 2023
I don't think we have a ready-made utility for that, so you'll have to
write code using the field domain API:
https://gdal.org/doxygen/classOGRCodedFieldDomain.html and
https://gdal.org/doxygen/classGDALDataset.html#a64d001fa0fe53c6aa51e983ca14bad39
With GDAL master, it might also be easier to use the -json output of
ogrinfo :
$ ogrinfo -json autotest/ogr/data/filegdb/Domains.gdb
"domains":{
"MedianType":{
"description":"Road median types.",
"type":"coded",
"fieldType":"Integer",
"fieldSubType":"Int16",
"splitPolicy":"default value",
"mergePolicy":"default value",
"codedValues":{
"0":"None",
"1":"Cement"
"RoadSurfaceType":{
"description":"The road surface type",
"type":"coded",
"codedValues":{
"1":"Asphalt",
"2":"Gravel",
"3":"Oiled Sand",
"4":"Dirt"
"SpeedLimit":{
"description":"The maximun speed of the road",
"type":"range",
"minValue":40,
"minValueIncluded":true,
"maxValue":100,
"maxValueIncluded":true
I can be imagine that a "Save as" context menu entry in QGIS would be a
cool enhancement.
Even
Le 17/01/2023 à 16:30, Totò Fiandaca a écrit :
> QGIS with gdal 3.6+ reads and writes gdb,
> how can I export field domains to dbf/csv tables?
> In the QGIS Browser I see the domains and I would like to export them
> in tables with at least two fields: code, description
> *Ing. Salvatore Fiandaca*
> *mobile*.:+39 327.493.8955
> *m*: *pigrecoinfinito at gmail.com <mailto:pigrecoinfinito at gmail.com>*
> *C.F*.: FNDSVT71E29Z103G
> *P.IVA*: 06597870820
> *membro QGIS Italia - http://qgis.it/*
> *socio GFOSS.it - *http://gfoss.it/
> *member OSGeo* - *https://www.osgeo.org/member/fiandaca/*
> <https://www.osgeo.org/member/fiandaca/>
> *blog:** https://pigrecoinfinito.com/ <https://pigrecoinfinito.com/>
> FB: Co-admin -
> https://www.facebook.com/qgis.it/**<https://www.facebook.com/qgis.it/> *
> *TW:<http://goog_95411464>**https://twitter.com/totofiandaca*
> 43°51'0.54"N 10°34'27.62"E - EPSG:4326
> “Se la conoscenza deve essere aperta a tutti,
> perchè mai limitarne l’accesso?”
> R. Stallman
> Questo documento, allegati inclusi, contiene informazioni di proprietà
> di FIANDACA SALVATORE e deve essere utilizzato esclusivamente dal
> destinatario in relazione alle finalità per le quali è stato ricevuto.
> E' vietata qualsiasi forma di riproduzione o divulgazione senza
> l'esplicito consenso di FIANDACA SALVATORE. Qualora fosse stato
> ricevuto per errore si prega di informare tempestivamente il mittente
> e distruggere la copia in proprio possesso.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230117/88682800/attachment.htm>
