[gdal-dev] How to extract field domains from a gdb
Totò Fiandaca
pigrecoinfinito at gmail.com
Tue Jan 17 08:46:19 PST 2023
wow!!!
>I can be imagine that a "Save as" context menu entry in QGIS would be a
cool enhancement.
Great, works great!!!
Please if you tell me how much you would like to implement it so I organize
a fundraiser.
Il giorno mar 17 gen 2023 alle ore 16:40 Even Rouault <
even.rouault at spatialys.com> ha scritto:
> Hi,
> I don't think we have a ready-made utility for that, so you'll have to
> write code using the field domain API:
> https://gdal.org/doxygen/classOGRCodedFieldDomain.html and
> https://gdal.org/doxygen/classGDALDataset.html#a64d001fa0fe53c6aa51e983ca14bad39
> With GDAL master, it might also be easier to use the -json output of
> ogrinfo :
> $ ogrinfo -json autotest/ogr/data/filegdb/Domains.gdb
> "domains":{
> "MedianType":{
> "description":"Road median types.",
> "type":"coded",
> "fieldType":"Integer",
> "fieldSubType":"Int16",
> "splitPolicy":"default value",
> "mergePolicy":"default value",
> "codedValues":{
> "0":"None",
> "1":"Cement"
> "RoadSurfaceType":{
> "description":"The road surface type",
> "type":"coded",
> "codedValues":{
> "1":"Asphalt",
> "2":"Gravel",
> "3":"Oiled Sand",
> "4":"Dirt"
> "SpeedLimit":{
> "description":"The maximun speed of the road",
> "type":"range",
> "minValue":40,
> "minValueIncluded":true,
> "maxValue":100,
> "maxValueIncluded":true
> cool enhancement.
> Even
> Le 17/01/2023 à 16:30, Totò Fiandaca a écrit :
> QGIS with gdal 3.6+ reads and writes gdb,
> how can I export field domains to dbf/csv tables?
> In the QGIS Browser I see the domains and I would like to export them in
> tables with at least two fields: code, description
> *Ing. Salvatore Fiandaca*
> *mobile*.:+39 327.493.8955
> *m*: *pigrecoinfinito at gmail.com <pigrecoinfinito at gmail.com>*
> *C.F*.: FNDSVT71E29Z103G
> *P.IVA*: 06597870820
> *membro QGIS Italia - http://qgis.it/ <http://qgis.it/>*
> *socio GFOSS.it - *http://gfoss.it/
> *member OSGeo* - *https://www.osgeo.org/member/fiandaca/*
> <https://www.osgeo.org/member/fiandaca/>
> *blog:*
> * https://pigrecoinfinito.com/ <https://pigrecoinfinito.com/> FB:
> Co-admin - https://www.facebook.com/qgis.it/
> <https://www.facebook.com/qgis.it/>**
> <https://www.facebook.com/qgis.it/> *
> *TW: <http://goog_95411464>**https://twitter.com/totofiandaca
> <https://twitter.com/totofiandaca>*
> 43°51'0.54"N 10°34'27.62"E - EPSG:4326
> “Se la conoscenza deve essere aperta a tutti,
> perchè mai limitarne l’accesso?”
> R. Stallman
> Questo documento, allegati inclusi, contiene informazioni di proprietà di
> FIANDACA SALVATORE e deve essere utilizzato esclusivamente dal destinatario
> in relazione alle finalità per le quali è stato ricevuto. E' vietata
> qualsiasi forma di riproduzione o divulgazione senza l'esplicito consenso
> di FIANDACA SALVATORE. Qualora fosse stato ricevuto per errore si prega
> di informare tempestivamente il mittente e distruggere la copia in proprio
> possesso.
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
*blog:*
* https://pigrecoinfinito.com/ <https://pigrecoinfinito.com/> FB: Co-admin
- https://www.facebook.com/qgis.it/ <https://www.facebook.com/qgis.it/>**
R. Stallman
di FIANDACA SALVATORE. Qualora fosse stato ricevuto per errore si prega di
possesso.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230117/a3ef5e01/attachment-0001.htm>
