[gdal-dev] Stitching and geo coordinating drone images
Bo Victor Thomsen bo.victor.thomsen at gmail.com
Fri Jan 20 00:07:11 PST 2023
Try WebODM (https://opendronemap.org/webodm/). It's an open-source tool
to this kind of work-flow.
Med venlig hilsen / Best regards
Bo Victor Thomsen
Den 20-01-2023 kl. 06:22 skrev Vaheed Ghaffari:
> Hello,
> I need some verification from the pros out there. I am trying to
> stitch together a set of images taken by the DJI drone camera (M300)
> and add geo coordination.
> Raw images are not geo coordinated, but I can access the photo
> information in XMP fields, including the coordinates of the image
> center (principal point). I am trying to use the GDAL C# Nuget Package.
> Here are the steps I am taking:
> 1- Calculate geotransform array 6 coefficients using the principal
> point coordinates, calculated GSD and camera pitch/yaw/roll for each image
> 2- Use setgeotransform assign the array to the images
> 3-Use GdalWarp try to stitch the geocoordinated images together.
> I am not getting any good results. the output of the Warp function is
> always a modified version of my last image in the dataset. I tried
> using a basic geotranform array (without roll or coordination move)
> for testing and got the same/similar results.
> I can provide the detailed code if required, but I have a feeling that
> I am missing steps.
> I appreciate the help,
> -Vaheed
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
