[gdal-dev] Updating the MVT tile set using ogr2ogr
Even Rouault
even.rouault at spatialys.com
Tue Jan 31 11:08:04 PST 2023
Actually you may need to actually use -clipdst to avoid generating
partial tiles.
Le 31/01/2023 à 20:02, Even Rouault a écrit :
> Linda,
> you'll have to do a bit of manual work. You may use the -spat option
> of ogr2ogr with bounds that exactly match the bounds of affected MVT
> tiles in EPSG:3857, and then move the generated .pbf tiles back to the
> full dataset.
> Even
> Le 31/01/2023 à 19:42, Linda Kladivová a écrit :
>> Hello guys,
>> it is possible to update the MVT tileset using ogr2ogr?
>> My data often changes and I would need to reseed tiles in the
>> specific area given by MBR.
>> I am looking for similar functionality as GeoServer provides
>> (https://docs.geoserver.org/latest/en/user/geowebcache/rest/seed.html).
>> Thank you for your answer.
>> Best regards,
>> Linda Kladivova
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
