[gdal-dev] Updating the MVT tile set using ogr2ogr
Linda Kladivová
L.Kladivova at seznam.cz
Tue Jan 31 11:19:38 PST 2023
Even,
thank you for your quick answer. Just one quick question - is it possible to
do what you suggest with vector tiles in a user-defined tiling scheme (CRS
which I use is EPSG:5514)?
Thanks!
Linda
---------- Původní e-mail ----------
Od: Even Rouault <even.rouault at spatialys.com>
Komu: Linda Kladivová <L.Kladivova at seznam.cz>, gdal-dev at lists.osgeo.org
Datum: 31. 1. 2023 20:08:08
Předmět: Re: [gdal-dev] Updating the MVT tile set using ogr2ogr
"Actually you may need to actually use -clipdst to avoid generating
partial tiles.
Le 31/01/2023 à 20:02, Even Rouault a écrit :
> Linda,
> you'll have to do a bit of manual work. You may use the -spat option
> of ogr2ogr with bounds that exactly match the bounds of affected MVT
> tiles in EPSG:3857, and then move the generated .pbf tiles back to the
> full dataset.
> Even
> Le 31/01/2023 à 19:42, Linda Kladivová a écrit :
>> Hello guys,
>> it is possible to update the MVT tileset using ogr2ogr?
>> My data often changes and I would need to reseed tiles in the
>> specific area given by MBR.
>> I am looking for similar functionality as GeoServer provides
>> (https://docs.geoserver.org/latest/en/user/geowebcache/rest/seed.html).
>> Thank you for your answer.
>> Best regards,
>> Linda Kladivova
>> gdal-dev mailing list
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230131/f5511d20/attachment-0001.htm>
