[gdal-dev] Create a GDAL VRT for a 3D image that transposes the image dimensions
Even Rouault even.rouault at spatialys.com
Fri Jun 2 11:38:06 PDT 2023
You may use the multidimensional API for that :
https://gdal.org/drivers/raster/vrt_multidimensional.html . Typically
the <SourceTranspose> element is relevant. Note however that on-the-fly
transposing can have bad performance, but for the relatively small image
you mention, that might be OK. That said, you'd may be better using the
MDim API ( https://gdal.org/tutorials/multidimensional_api_tut.html)
directly to get a numpy array and use numpy native transpose capabilities.
Le 02/06/2023 à 18:30, Daniel Scheffler a écrit :
> Hi!
> I have an image with 500 rows, 1000 columns, and 2 bands in a NetCDF
> file which stores the data in the following scheme:
> - dimension 1: rows
> - dimension 2: bands
> - dimension 3: columns
> If I now do gdal.Open('filepath').GetRasterBand(1).ReadAsArray(), I
> get a numpy array in the shape 500x2. Is it somehow possible to create
> a GDAL VRT that accesses the data as rows/columns/bands instead of
> rows/bands/columns? If yes, how would I create such a VRT using the
> Python API?
> Best,
> Daniel
http://www.spatialys.com
