[gdal-dev] Java API: how to find dimensions of MDArray
Barry DeZonia bdezonia at gmail.com
Fri Jun 2 22:18:09 PDT 2023
Hi all,
I have access to an MDArray. I am trying to find its dimensions. In the C++
API I can see that GDALMDArray has a method called GetDimensions() to find
the info I need. But I am programming in Java and the Java API does not
show such a call for MDArray. Is there some way in Java to find the info I
need?
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230603/b9f0b789/attachment.htm>
