[gdal-dev] Java API: how to find dimensions of MDArray
Even Rouault
even.rouault at spatialys.com
Sat Jun 3 09:03:16 PDT 2023
Le 03/06/2023 à 17:45, Barry DeZonia a écrit :
> Thanks Even.
> I might be able to find some time to do the SWIG work depending upon
> the amount of development time needed. I am a long time developer with
> experience in Java, C, and C++ (but have not used SWIG before). Is it
> just a few signatures I need to write or do I need to write full
> support for a GDALDimension class? Can you comment on this?
Yes this is "just" a few signatures to map a C array of (existing)
GDALDimensionH objects to a vector of Java counterpart
org.gdal.gdal.Dimension objects. The org.gdal.gdal.Dimension class
already exists, with a "Dimension(long cPtr, boolean cMemoryOwn)"
constructor taking the value of the underlying C pointer as a Java long.
The cMemoryOwn boolean should probably be passed to true in that
context, since the C GDALDimensionH objects need to be freed at the
finalization of the Java Dimension object. This is really about glueing
stuff, but that said writing SWIG typemaps is a whole adventure in
itself... You may find relevant documentation at
https://www.swig.org/Doc4.1/SWIGDocumentation.html#Java_typemaps . The
hint I gave for the existing closest typemap should hopefully put you on
the right track, or at least as close as possible.
> Am I right in understanding that, as of the current Java
> implementation, one really can't use MDArrays for much? Like if I
> can't find the number of (... z planes, t steps, channels, etc.) of
> data I will not be able to reconstruct the data?
Yes the multidim API is probably currently hardly usable outside C, C++
and Python due to the lack of a few critical typemaps for the other
languages.
Even
> On Sat, Jun 3, 2023 at 6:09 AM Even Rouault
> <even.rouault at spatialys.com> wrote:
> Barry,
> This method is indeed not available currently in the Java
> bindings. It is only available currently in the Python bindings
> (see
> https://github.com/OSGeo/gdal/blob/master/swig/include/MultiDimensional.i#L159
> ) , since it requires writing a specific SWIG typemap for each
> binding language when a method returns (or takes as argument) a
> new non-primitive type such as here, with an array of dimensions.
> The closest existing Java typemap I found that can be used to take
> inspiration from is
> https://github.com/OSGeo/gdal/blob/master/swig/include/java/typemaps_java.i#L235
> but there would be changes to call the "Dimension(long cPtr,
> boolean cMemoryOwn)" constructor. Whether you want to try to
> tackle that yourself or not, you may create a ticket about that
> Even
> Le 03/06/2023 à 09:09, Barry DeZonia a écrit :
>> On a related note is the Java api code in a public repo
>> somewhere? It would be helpful to look at that code sometimes.
>> (Like is GetDimensions() present in the Java code but not exposed
>> as a public method?)
>> On Sat, Jun 3, 2023 at 12:18 AM Barry DeZonia
>> <bdezonia at gmail.com> wrote:
>> Hi all,
>> I have access to an MDArray. I am trying to find its
>> dimensions. In the C++ API I can see that GDALMDArray has a
>> method called GetDimensions() to find the info I need. But I
>> am programming in Java and the Java API does not show such a
>> call for MDArray. Is there some way in Java to find the info
>> I need?
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230603/f249c572/attachment-0001.htm>
