[gdal-dev] Two questions about Java API
    Even Rouault
    even.rouault at spatialys.com
    Wed Jun  7 01:47:19 PDT 2023
Barry,
you can't instantiate the objects directly. They are tied to an
underlying driver.
You could for example port this subset of those tests of the MEM driver:
https://github.com/OSGeo/gdal/blob/master/autotest/gdrivers/memmultidim.py#L85
and
https://github.com/OSGeo/gdal/blob/master/autotest/gdrivers/memmultidim.py#L188
. Note that they test a bit more than just the API, but also the
implementation of the MEM driver, so you don't need to test all error
cases for example
Even
Le 07/06/2023 à 04:54, Barry DeZonia a écrit :
> Hello,
> I am trying to extend the Java API so that the MDArray code is more
> full featured. Right now I am working on extending Attribute to return
> a Vector<Dimension> when Attribute::GetDimensions() is called. Much of
> this support is missing and I am in the process of wiring it up. I am
> starting to write test code to drive development and have two
> questions about my test code. I am pasting the code below with
> questions inlined.
> private static void testGetDimensions() {
>     // QUESTION 1:
>     // how do I create a Group programmatically?
>     Group group1 = new Group("universe1");  // NOPE
>     Group group2 = Group.CreateGroup("universe2");  // NOPE
>     // QUESTION 2:
>     // What is a SWIGTYPE_p_GUIntBig?
>     //  Is this type exposed in MDArray API as a flaw in the current
> Java API?
>     //  See API docs for MDArray::CreateAttribute()
>     group1.CreateAttribute("jane",
>                                 1,
>                                 null,  // wants an array of
> SWIGTYPE_p_GUIntBig
> ExtendedDataType.Create(gdalconst.GDT_UInt16));
>     Attribute attribute = group.GetAttribute("jane");
>     Vector<Dimension> dims = attribute.GetDimensions();
> So can anyone answer my two questions? Am I approaching this right?
> Thanks for any info.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
