[gdal-dev] Two questions about Java API
Even Rouault
even.rouault at spatialys.com
Wed Jun 7 09:21:51 PDT 2023
Sorry, missed the question
You need to create a typemap for "(int nList, GUIntBig* pList)" that can
be mapped to an a long[] in Java. You probably don't care about the
range of uint64_t (GUIntBig is a GDAL specific alias of uint64_t) that
cannot be mapped to a int64_t, so no need to go with Biginteger[]
Such typemap should be similar to the existing "(int nList, int* pList)" one
SWIG indeed generates rather dummy SWIGTYPE_p_xxxx types when there are
missing typemaps. When such types appear in the Java API it means that a
typemap is missing
Even
Le 07/06/2023 à 18:03, Barry DeZonia a écrit :
> Thanks Even. I'll look at this later. But you only answered one of my
> questions. The type SWIGTYPE_p_GUIntBig is specified in the Java API
> for CreateAttribute(). No such thing is shown in the python tests you
> showed me. I would suspect because python has unlimited range integers
> and an array for them will work just fine, But this weird SWIG type in
> Java seems misplaced. What should the signature be? dimensions as
> lon[]? dimensions as Biginteger[]? And if so then why is the current
> signature so messy with this SWIG type. If it is supposed to be this
> weird SWIG type then how do I create it? The Java api javadoc does not
> show it has any useful methods.
> On Wed, Jun 7, 2023 at 3:47 AM Even Rouault
> <even.rouault at spatialys.com> wrote:
> Barry,
> you can't instantiate the objects directly. They are tied to an
> underlying driver.
> You could for example port this subset of those tests of the MEM
> driver:
> https://github.com/OSGeo/gdal/blob/master/autotest/gdrivers/memmultidim.py#L85
> and
> https://github.com/OSGeo/gdal/blob/master/autotest/gdrivers/memmultidim.py#L188
> . Note that they test a bit more than just the API, but also the
> implementation of the MEM driver, so you don't need to test all error
> cases for example
> Even
> Le 07/06/2023 à 04:54, Barry DeZonia a écrit :
> > Hello,
> > I am trying to extend the Java API so that the MDArray code is more
> > full featured. Right now I am working on extending Attribute to
> return
> > a Vector<Dimension> when Attribute::GetDimensions() is called.
> Much of
> > this support is missing and I am in the process of wiring it up.
> I am
> > starting to write test code to drive development and have two
> > questions about my test code. I am pasting the code below with
> > questions inlined.
> > private static void testGetDimensions() {
> > // QUESTION 1:
> > // how do I create a Group programmatically?
> > Group group1 = new Group("universe1"); // NOPE
> > Group group2 = Group.CreateGroup("universe2"); // NOPE
> > // QUESTION 2:
> > // What is a SWIGTYPE_p_GUIntBig?
> > // Is this type exposed in MDArray API as a flaw in the
> current
> > Java API?
> > // See API docs for MDArray::CreateAttribute()
> > group1.CreateAttribute("jane",
> > 1,
> > null, // wants an array of
> > SWIGTYPE_p_GUIntBig
> > ExtendedDataType.Create(gdalconst.GDT_UInt16));
> > Attribute attribute = group.GetAttribute("jane");
> > Vector<Dimension> dims = attribute.GetDimensions();
> > So can anyone answer my two questions? Am I approaching this right?
> > Thanks for any info.
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230607/9b5dd2e1/attachment.htm>
