[gdal-dev] gdalinfo on large vrt takes a long time
Even Rouault
even.rouault at spatialys.com
Thu Jun 8 16:18:15 PDT 2023
William,
it might be perhaps related to the GetMinimum() call done by gdalinfo.
Cf https://trac.osgeo.org/gdal/ticket/5444
But normally it should only try to open the first source, and not all of
them. At least that's what I could confirm on a quick testing. But I do
see that the CanUseSourcesMinMaxImplementations() method will stat()
sources whose filename looks like a local file (obviously if that's a
mounted file system / vpn thing, it will not realize it is remote).
Try setting the VRT_MIN_MAX_FROM_SOURCES=NO environment variable /
configuration option to see if that makes a difference. If it does, the
CanUseSourcesMinMaxImplementations() logic should be modified to avoid
doing those stat's().
If that's confirmed to be linked to GetMinmum(), you may also workaround
the issue by doing a "gdalinfo -stats the.vrt" (from the server) to have
statistics incorporated in the VRT, then GetMinimum() should be instant
Even
Le 09/06/2023 à 00:43, William Kyngesburye a écrit :
> I'm writing a script that needs some info from a vrt raster, and one has thousands of files. When reading the vrt over the internet (vpn to our server) it takes a long time. I think it's looking at every file of the vrt. What is gdal reading from the files that's not in the vrt itself? I used all the -no options and I'm not adding any other info options like checksums or stats. I just need basic info from the vrt that's in the vrt file.
> William Kyngesburye
> <kyngchaos*at*kyngchaos*dot*com>
> <https://www.kyngchaos.com>
> Don't Panic
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
