[gdal-dev] Compatibility of GDAL binaries and GDAL jar files
Even Rouault
even.rouault at spatialys.com
Tue Jun 13 13:37:09 PDT 2023
Le 13/06/2023 à 22:27, Dirk Stenger a écrit :
> All,
> I am using GDAL with an Java application and have a couple of
> questions regarding the compatibility of releases of the GDAL binaries
> and the GDAL jar files provided via Maven Central Repository [1].
> The GDAL jar files provided via Maven Central Repository never contain
> a bug fix version (e.g. 3.5.0, 3.6.0, 3.7.0). The GDAL binaries,
> however, use bug fix versions (e.g. 3.6.4).
> How do I match the versions? Should I, for example, use GDAL jar 3.6.0
> with GDAL binary 3.6.4?
Yes, that should work
> What is the release policy of the versions in Maven Central
> Repository, is there always a new jar release whenever there is a GDAL
> release of a minor version?
We generally don't release .jar for patch versions (the z in x.y.z),
unless there would be a bugfix for the bindings themselves
> Is there any compatibility scheme/matrix for using the GDAL jar file
> with GDAL binaries?
> For example, can minor versions be combined (e.g. using GDAL jar 3.0.0
> with GDAL binary 3.6.4) or should there always be exact version matching?
You could likely using a GDAL jar of a lesser version than the binary,
since the bindings rely on the C API/ABI which is stable within the same
major version number (but the reverse would be true. GDAL jar of 3.6
might use C symbols missing in libgdal < 3.6).
But such mixed version combinations are not tested by our CI : the CI
only tests running the bindings against the same GDAL native version.
I'm not totally sure you can run a .jar against the
libgdalalljni.so/.dll that would have been generated with a different
version of SWIG though. I assume that if you remain with the same major
version of SWIG that should work OK, but that's not tested either.
http://www.spatialys.com
