[gdal-dev] libtiff 4.5.1 is released
Even Rouault even.rouault at spatialys.com
Wed Jun 14 09:06:45 PDT 2023
Le 14/06/2023 à 17:57, Jeff McKenna a écrit :
> Thanks Even.  One question (for packagers), is if the tools you
> mentioned to be removed are set through -Dtiff-contrib correct?
This is still to be decided how we implement this. There's a discussion
in https://gitlab.com/libtiff/libtiff/-/issues/580
"contrib" are even less supported/maintained stuff. We should probably
not build them by default either.
Een
http://www.spatialys.com
