[gdal-dev] OAPIF Unexpected Content-Type
Denis Rykov rykovd at gmail.com
Wed Jun 14 13:43:26 PDT 2023
That was it. Thanks Even!
On Thu, Jun 1, 2023 at 2:09 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> Denis,
> You have to identify on which request this occurs
> Run with CPL_DEBUG=ON CPL_CURL_VERBOSE=ON
> This error is emitted when the server issues a response with a missing
> Content-Type header.
> Le 01/06/2023 à 01:52, Denis Rykov a écrit :
> > I'm getting "ERROR 1: Unexpected Content-Type: (null)" in the middle
> > of the ogrinfo output. What does this mean? I can adjust server
> > configuration but it is not clear which endpoint is failing because
> > apart from that message everything seems to be working fine.
> > $ ogrinfo OAPIF:http://localhost:8080/api/resource/6750/oapif/
> layer_6209
> > INFO: Open of `OAPIF:http://localhost:8080/api/resource/6750/oapif/'
> >       using driver `OAPIF' successful.
> > Layer name: layer_6209
> > Metadata:
> >   TITLE=Test layer
> > Geometry: Point
> > Feature Count: 26
> > Extent: (0.000000, 0.000000) - (110.275300, 49.493019)
> > Layer SRS WKT:
> > GEOGCRS["WGS 84",
> >     DATUM["World Geodetic System 1984",
> >         ELLIPSOID["WGS 84",6378137,298.257223563,
> >             LENGTHUNIT["metre",1]]],
> >     PRIMEM["Greenwich",0,
> >         ANGLEUNIT["degree",0.0174532925199433]],
> >     CS[ellipsoidal,2],
> >         AXIS["geodetic latitude (Lat)",north,
> >             ORDER[1],
> >         AXIS["geodetic longitude (Lon)",east,
> >             ORDER[2],
> >     ID["EPSG",4326]]
> > Data axis to CRS axis mapping: 2,1
> > num: Real (0.0)
> > link: String (0.0)
> > wikipedia: String (0.0)
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230614/7d211998/attachment.htm>
