[gdal-dev] OGR CSV oddity
Scott public at postholer.com
Sat Jun 17 09:00:48 PDT 2023
Weird. Thanks Even!
On 6/17/23 08:58, Even Rouault wrote:
> yep, known oddity. Presumably out of caution, the CSV driver refused for
> years to open a CSV with a single column, so on the writing side, it
> adds this dummy comma. Since recently (3.7.0 I believe), the read side
> of the CSV accepts single column header without trailing comma, but the
> write side still generates one
> Le 17/06/2023 à 17:54, Scott a écrit :
>> If I select a single column from a table, the header column name has a
>> trailing comma. If I select more than 1 column it does not. Example:
>> ogr2ogr -f CSV -sql "select col1 from table limit 1" /vsistdout/
>> source.gpkg
>> Output:
>> col1,
>> 123
>> Tested on 3.5.1 and 3.7
>> I've tried this on various column data types with the same result.
>> Pseudo suggestion:
>> header += header.length ? "," + colname : colname
