[gdal-dev] OSX 13.4 (M1 Pro) troubles using GDAL
Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND APPLICATIONS INC]
jesse.r.meyer at nasa.gov
Tue Jun 20 13:43:44 PDT 2023
My GDAL installation procedure looks like:
Install python 3.11.4 from the official site
brew install gdal (this grabbed numpy v1.25, and a number of other pre-reqs, and installs 3.6.4)
python -m venv test_env
// activate test_env //
pip install numpy (installs v1.25)
pip install gdal==3.6.4 (brew does not yet house 3.7)
This appears to work fine at first. I can manipulate gdal datasets up until I use band.ReadAsArray(). Python throws an exception `cannot import name '_gdal_array' from 'osgeo`.
Should this have worked? Stack Overflow has a few instances of this problem and they all point to incorrect install orders, or various software environments interacting poorly. But I don’t think I’m making those mistakes.
What causes my head to spin is that, I installed rasterio, and the ‘read’ function works! It must be via a different mechanism, but I wasn’t able to follow the code architecture in Github to see how they pull it off.
Any advice? Thanks --
Jesse
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230620/e63c773a/attachment.htm>
