[gdal-dev] gdal_translate tiff to netcdf
Abigaïl Dah
adah at uvic.ca
Tue Jun 20 16:37:14 PDT 2023
Hello,
I am trying to convert a file with the format GEOTIFF to netcdf using the command line:
gdal_translate -of NetCDF <input filename> <output filename>
However, I get the following error message: Output driver `NetCDF' not recognised.
Would you know what's wrong and how to fix this? Thanks in advance,
Best,
Abigail
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230620/ccd5f0b3/attachment.htm>
