[gdal-dev] gdal_translate tiff to netcdf
Scott public at postholer.com
Tue Jun 20 17:17:24 PDT 2023
It sounds like the install wasn't built with libnetCDF. Try this:
gdalinfo --formats
If it's part of your install you'll see it.
On 6/20/23 16:37, Abigaïl Dah wrote:
> Hello,
> I am trying to convert a file with the format GEOTIFF to netcdf using
> the command line:
> gdal_translate -of NetCDF <input filename> <output filename>
> However, I get the following error message: Output driver `NetCDF' not
> recognised.
> Would you know what’s wrong and how to fix this? Thanks in advance,
> Best,
> Abigail
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
