[gdal-dev] ESRI Shapefile API missing
Derek Newhall
dnewhall at carlsonsw.com
Tue Jun 20 18:01:07 PDT 2023
Hi all,
We've just migrated from GDAL 3.5.1 to 3.7.0 which we build with (almost)
all external dependencies as static libraries. However, we've noticed that
when we try to compile our app against the resulting library the ESRI
Shapefile API isn't available.
Severity Code Description
Error LNK2001 unresolved external symbol DBFClose
Error LNK2001 unresolved external symbol SHPOpen
<snip>
Error LNK2001 unresolved external symbol SHPCreateObject
Error LNK2001 unresolved external symbol SHPClose
Looking at the .libs' symbols:
DUMPBIN /linkermember D:\gdal-3.5.1\build\gdal_i.lib | sls DBF
1ED958 DBFOpen
1ED958 __imp_DBFOpen
1ED9BC DBFOpenLL
1ED9BC __imp_DBFOpenLL
1ED3D0 DBFCreate
1ED3D0 __imp_DBFCreate
1ED436 DBFCreateEx
1ED436 __imp_DBFCreateEx
<snip 50+ lines>
1257 __imp_DBFWriteNULLAttribute
1256 __imp_DBFWriteStringAttribute
125B __imp_DBFWriteTuple
DUMPBIN /linkermember D:\gdal-3.7.0\build\gdal.lib | sls DBF
DBF OSRGetAxesCount
DBF __imp_OSRGetAxesCount
We build the DLL and apps with the following command in a .bat script (all
library paths are valid and it compiles):
cmake -G "Visual Studio 16 2019" -DBUILD_APPS=ON -DBUILD_SHARED_LIBS=ON ^
-DCMAKE_BUILD_TYPE=RelWithDebInfo -DCMAKE_PREFIX_PATH=D:\gdal-3.7.0-build ^
-DCMAKE_CXX_FLAGS="-DCURL_STATICLIB -DXML_STATIC"
-DGDAL_USE_EXTERNAL_LIBS=OFF ^
-DOGR_BUILD_OPTIONAL_DRIVERS=ON ^
-DPROJ_INCLUDE_DIR="%~dp0proj-6.3.1\src" ^
-DPROJ_LIBRARY_RELEASE="%~dp0proj-6.3.1\build_VS2017_x64\lib\RelWithDebInfo\proj.lib"
-DGDAL_USE_CURL=ON -DCURL_INCLUDE_DIR="%~dp0libcurl\include"
-DCURL_LIBRARY_RELEASE="%~dp0libcurl\lib\libcurl.lib" ^
-DGDAL_USE_ECW=ON -DECW_INCLUDE_DIR="%~dp0ERDAS ECW JPEG 2000 SDK
5.5.0\Desktop Read-Only\include" -DECW_LIBRARY="%~dp0ERDAS ECW JPEG 2000
SDK 5.5.0\Desktop Read-Only\lib\vc141\x64\NCSEcw.lib" ^
-DGDAL_USE_ODBC=ON ^
-DGDAL_USE_OPENSSL=ON -DOPENSSL_ROOT_DIR="%~dp0openssl-1.1.0f-vs2017"
-DOPENSSL_USE_STATIC_LIBS=TRUE -DOPENSSL_MSVC_STATIC_RT=TRUE ^
-DGDAL_ENABLE_DRIVER_PDF_PLUGIN=ON ^
-DGDAL_USE_PDFIUM=ON
-DPDFIUM_INCLUDE_DIR="%~dp0ExtractPDFium\install\include\pdfium"
-DPDFIUM_LIBRARY="%~dp0ExtractPDFium\install\lib\pdfium.lib" ^
-DGDAL_USE_SQLITE3=ON
-DSQLite3_INCLUDE_DIR="%~dp0sqlite-amalgamation-3370200"
-DSQLite3_LIBRARY="%~dp0sqlite-amalgamation-3370200\sqlite3.lib" ^
-DGDAL_USE_XERCESC=ON -DXercesC_INCLUDE_DIR="%~dp0xerces-c-3.2.4\src"
-DXercesC_LIBRARY="%~dp0xerces-c-3.2.4\build\src\Release\xerces-c_3.lib" ^
-DGDAL_USE_EXPAT=ON -DEXPAT_INCLUDE_DIR="%~dp0Expat\lib"
-DEXPAT_LIBRARY="%~dp0Expat\RelWithDebInfo\libexpat.lib" ^
The build documentation at
https://gdal.org/development/building_from_source.html says the ESRI
Shapefile API cannot be disabled, so I'm wondering what's going on. Is
this a bug, or did we just misconfigure something? This is our first time
semi-successfully building with the new CMake system.
Derek Newhall
Disclaimer
The information contained in this communication from the sender is confidential. It is intended solely for use by the recipient and others authorized to receive it. If you are not the recipient, you are hereby notified that any disclosure, copying, distribution or taking action in relation of the contents of this information is strictly prohibited and may be unlawful.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230620/1e10a942/attachment-0001.htm>
