[gdal-dev] Can we do Delaunay with 3D points?
Even Rouault even.rouault at spatialys.com
Sun Jun 25 11:05:27 PDT 2023
Joaquim,
> Looked at the GDAL tests and there it also uses only 2D (a 3D test is
> commented).
I assume you're speaking about the PolyhedralSurface / TIN tests in
ogr_geom.py.  The reason is that the code (and in particularly GEOS) is
not ready for those geometry types.
> I am doing something wrong or delaunay in GDAL is only possible with
> with 2D points?
Quick testing shows that it works with a multipoint z with a recent GEOS
master version  (but might work with older ones perhaps)
 >>> g = ogr.CreateGeometryFromWkt("MULTIPOINT Z (0 0 10,0 1 10,1 1 12,1
0 10)")
 >>> triangulation = g.DelaunayTriangulation()
 >>> triangulation.ExportToWkt()
'GEOMETRYCOLLECTION (POLYGON ((0 1 10,0 0 10,1 0 10,0 1 10)),POLYGON ((0
1 10,1 0 10,1 1 12,0 1 10)))'
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230625/9f196b5b/attachment.htm>
