[gdal-dev] Can we do Delaunay with 3D points?
    Joaquim Manuel Freire Luís
    jluis at ualg.pt
    Sun Jun 25 11:30:25 PDT 2023
Thanks Even
Your example actually also works for me too.
julia> g1 = fromWKT("MULTIPOINT Z(0 0 10,0 1 10,1 1 12,1 0 10)");
julia> d = delaunay(g1,0.0,false)
Geometry: GEOMETRYCOLLECTION (POLYGON ((0 1 10,0 0 10,1 0 10 ... 10)))
julia> toWKT(d)
"GEOMETRYCOLLECTION (POLYGON ((0 1 10,0 0 10,1 0 10,0 1 10)),POLYGON ((0 1 10,1 0 10,1 1 12,0 1 10)))"
It’s when I try to extract the data into a table (a GMT type) that the problem arises.
My code, so up to me to fix it.
julia> gd2gmt(d)
ERROR 6: Incompatible geometry for operation
BoundingBox: [0.0, 0.0, 0.0, 0.0, 0.0, 0.0]
2×3 GMTdataset{Float64, 2}
Row │   col.1    col.2    col.3
     │ Float64  Float64  Float64
   1 │     0.0      0.0      0.0
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of Even Rouault
Sent: Sunday, June 25, 2023 7:05 PM
To: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Can we do Delaunay with 3D points?
Joaquim,
Looked at the GDAL tests and there it also uses only 2D (a 3D test is commented).
I assume you're speaking about the PolyhedralSurface / TIN tests in ogr_geom.py.  The reason is that the code (and in particularly GEOS) is not ready for those geometry types.
I am doing something wrong or delaunay in GDAL is only possible with with 2D points?
Quick testing shows that it works with a multipoint z with a recent GEOS master version  (but might work with older ones perhaps)
>>> g = ogr.CreateGeometryFromWkt("MULTIPOINT Z (0 0 10,0 1 10,1 1 12,1 0 10)")
>>> triangulation = g.DelaunayTriangulation()
>>> triangulation.ExportToWkt()
'GEOMETRYCOLLECTION (POLYGON ((0 1 10,0 0 10,1 0 10,0 1 10)),POLYGON ((0 1 10,1 0 10,1 1 12,0 1 10)))'
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230625/e3798345/attachment-0001.htm>
