[gdal-dev] Multi-threaded GDALPolygonize C++
Even Rouault
even.rouault at spatialys.com
Mon Jun 26 10:04:34 PDT 2023
Shayan,
make sure to read https://gdal.org/user/multithreading.html . I suspect
you use the same GDAL Dataset or RasterBand object from multiple
threads, which isn't allowed
Even
Le 26/06/2023 à 18:38, Shayan Ghofrany a écrit :
> Good afternoon everyone,
> I'm new to the mailing list, so if my question is not formatted
> correctly please let me know.
> I am attempting to polygonize a raster file by first chunking it into
> smaller pieces and then using multi-threaded to polygonize those
> chunks simultaneously. I often come across Disk I/O errors which makes
> me think that what I want to do is not necessarily how GDALPolygonize
> should be used. I was wondering if anyone has attempted something
> similar and whether there are public examples available that I could
> look into.
> Thanks for your time,
> Shayan Ghofrany
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
