[gdal-dev] Convex hull with holes
Paul Meems
bontepaarden at gmail.com
Fri Mar 3 04:51:36 PST 2023
How can I algorithmically create a parcel border that accounts for islands
or holes within the parcel based on a list of coordinates?
While GDAL+GEOS has a Convex hull method, it only identifies the outer
border.
Has GDAL+GEOS a method that I can use to detect inner holes as well, such
as in a donut-shaped field?
The output can be json or shapefile, that doesn't matter.
Thanks,
Paul Meems
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230303/9772b478/attachment.htm>
