[gdal-dev] Convex hull with holes
Rahkonen Jukka
jukka.rahkonen at maanmittauslaitos.fi
Fri Mar 3 05:13:31 PST 2023
So you have an uncategorized bunch of points and you wish to have an algorithm that recognizes outer and inner rings automatically? I fear that is not as easy as it may appear. Have a look at the annexed image with two polygons having the same vertices. How could an algorithm know which interpretation is correct? In this simple case you could make a convex hull, delete the vertices which were consumed for the outer ring, and create a new ring from the remaining points, but generally it will not work if there are two holes, for example.
If the points come from a GPX device, make the application to record indexes for both the points and the rings “ring1-point1, ring1-point2---ring2-point1,ring2-point2” and construct the polygon ring by ring.
-Jukka Rahkonen-
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta Paul Meems
Lähetetty: perjantai 3. maaliskuuta 2023 14.52
Vastaanottaja: gdal-dev at lists.osgeo.org
Aihe: [gdal-dev] Convex hull with holes
How can I algorithmically create a parcel border that accounts for islands or holes within the parcel based on a list of coordinates?
While GDAL+GEOS has a Convex hull method, it only identifies the outer border.
Has GDAL+GEOS a method that I can use to detect inner holes as well, such as in a donut-shaped field?
The output can be json or shapefile, that doesn't matter.
Thanks,
Paul Meems
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230303/c05fb4ae/attachment-0001.htm>
Type: image/png
Desc: two_polygons.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230303/c05fb4ae/attachment-0001.png>
