[gdal-dev] ERROR 1: No inverse operation
Javier Jimenez Shaw j1 at jimenezshaw.com
Wed Mar 8 03:48:43 PST 2023
gdalinfo is usually showing the coordinates of the corners and center in
the CRS of the GeoTIFF, and also in WGS84 in degrees as conversion of the
previous. Looks like your CRS does not support such conversion.
If you paste the full output of gdalinfo there should be some clues about
the CRS used.
Cheers,
Javier
On Wed, 8 Mar 2023 at 09:37, Micha Silver <tsvibar at gmail.com> wrote:
> I received some Geotiff files, and gdalinfo shows:
> Corner Coordinates:
> Upper Left  (  205370.241,  418790.721)
> Lower Left  (  205370.241,  415665.721)
> Upper Right (  206198.866,  418790.721)
> Lower Right (  206198.866,  415665.721)
> Center      (  205784.553,  417228.221)
> What does that mean?
> gdalinfo --version
> GDAL 3.6.2, released 2023/01/02
> Thanks
> Micha Silver
> Remote Sensing Lab, Sde Boker
> Ben Gurion University
> +972-523-665918
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230308/229110d8/attachment.htm>
