[gdal-dev] ERROR 1: No inverse operation
Even Rouault
even.rouault at spatialys.com
Wed Mar 8 09:30:58 PST 2023
The file is indeed fine and was recognized in earlier GDAL versions (<=
3.4). Bug fixed per https://github.com/OSGeo/gdal/pull/7382
Le 08/03/2023 à 14:22, Micha Silver a écrit :
> Inline...
> On 08/03/2023 14:33, Even Rouault wrote:
>> Ah, the issue here is that the GeoTIFF keys in the .tif partially
>> define the projection (or possibly the .tif.aux.xml contain this
>> invalid WKT). But METHOD["unnamed"] means that the projection method
>> is unknown, so it is logical that GDAL/PROJ can't compute geographic
>> coordinates from projected coordinates.
>> The output of "listgeo HiBar_21022022_A1.tif" might be useful to
>> further diagnose.
> I can't see any problem here:
> Geotiff_Information:
> Version: 1
> Key_Revision: 1.0
> Tagged_Information:
> ModelTiepointTag (2,3):
> 0 0 0
> 202245.240786848 421915.720555977 0
> ModelPixelScaleTag (1,3):
> 0.125 0.125 1
> End_Of_Tags.
> Keyed_Information:
> GTModelTypeGeoKey (Short,1): ModelTypeProjected
> GTRasterTypeGeoKey (Short,1): RasterPixelIsArea
> GTCitationGeoKey (Ascii,26): "PCS Name = Israel_TM_Grid"
> GeographicTypeGeoKey (Short,1): Code-4141 (Israel 1993)
> GeogAngularUnitsGeoKey (Short,1): Angular_Degree
> GeogEllipsoidGeoKey (Short,1): Ellipse_GRS_1980
> GeogSemiMajorAxisGeoKey (Double,1): 6378137
> GeogSemiMinorAxisGeoKey (Double,1): 6356752.31414036
> GeogInvFlatteningGeoKey (Double,1): 298.257222101
> GeogTOWGS84GeoKey (Double,7): -48 55 52
> 0 0 0
> 0
> ProjectedCSTypeGeoKey (Short,1): Code-2039 (Israel 1993 / Israeli
> TM Grid)
> PCSCitationGeoKey (Ascii,15): "Israel_TM_Grid"
> ProjLinearUnitsGeoKey (Short,1): Linear_Meter
> End_Of_Keys.
> End_Of_Geotiff.
> PCS = 2039 (Israel 1993 / Israeli TM Grid)
> Projection = 18204 (Israeli TM)
> Projection Method: CT_TransverseMercator
> ProjNatOriginLatGeoKey: 31.734394 ( 31d44' 3.82"N)
> ProjNatOriginLongGeoKey: 35.204517 ( 35d12'16.26"E)
> ProjScaleAtNatOriginGeoKey: 1.000007
> ProjFalseEastingGeoKey: 219529.584000 m
> ProjFalseNorthingGeoKey: 626907.390000 m
> GCS: 4141/Israel 1993
> Datum: 6141/Israel 1993
> Ellipsoid: 7019/GRS 1980 (6378137.00,6356752.31)
> Prime Meridian: 8901/Greenwich (0.000000/ 0d 0' 0.00"E)
> TOWGS84: -48,55,52,0,0,0,0
> Projection Linear Units: 9001/metre (1.000000m)
> Corner Coordinates:
> Upper Left ( 202245.241, 421915.721) ( 35d 1'32.11"E, 29d53'
> 7.03"N)
> Lower Left ( 202245.241, 418790.721) ( 35d 1'32.29"E,
> 29d51'25.54"N)
> Upper Right ( 205370.241, 421915.721) ( 35d 3'28.57"E, 29d53'
> 7.17"N)
> Lower Right ( 205370.241, 418790.721) ( 35d 3'28.72"E,
> 29d51'25.68"N)
> Center ( 203807.741, 420353.221) ( 35d 2'30.42"E, 29d52'16.36"N)
> Then, after:
> gdal_translate -a_srs EPSG:2039 HiBar_21022022_A1.tif
> HiBar_21022022_A1b.tif
> The ERROR goes away and I get:
> gdalinfo HiBar_21022022_A1b.tif
> Driver: GTiff/GeoTIFF
> Files: HiBar_21022022_A1b.tif
> Size is 25000, 25000
> Coordinate System is:
> PROJCRS["Israel 1993 / Israeli TM Grid",
> BASEGEOGCRS["Israel 1993",
> DATUM["Israel 1993",
> ELLIPSOID["GRS 1980",6378137,298.257222101,
> LENGTHUNIT["metre",1]]],
> PRIMEM["Greenwich",0,
> ANGLEUNIT["degree",0.0174532925199433]],
> ID["EPSG",4141]],
> CONVERSION["Israeli TM",
> METHOD["Transverse Mercator",
> ID["EPSG",9807]],
> PARAMETER["Latitude of natural origin",31.7343936111111,
> ANGLEUNIT["degree",0.0174532925199433],
> ID["EPSG",8801]],
> PARAMETER["Longitude of natural origin",35.2045169444444,
> ID["EPSG",8802]],
> PARAMETER["Scale factor at natural origin",1.0000067,
> SCALEUNIT["unity",1],
> ID["EPSG",8805]],
> PARAMETER["False easting",219529.584,
> LENGTHUNIT["metre",1],
> ID["EPSG",8806]],
> PARAMETER["False northing",626907.39,
> ID["EPSG",8807]]],
> CS[Cartesian,2],
> AXIS["(E)",east,
> ORDER[1],
> LENGTHUNIT["metre",1]],
> AXIS["(N)",north,
> ORDER[2],
> USAGE[
> SCOPE["Cadastre, engineering survey, topographic mapping (large
> and medium scale)."],
> AREA["Israel - onshore; Palestine Territory - onshore."],
> BBOX[29.45,34.17,33.28,35.69]],
> ID["EPSG",2039]]
> Data axis to CRS axis mapping: 1,2
> Origin = (202245.240786847687559,421915.720555976789910)
> Pixel Size = (0.125000000000000,-0.125000000000000)
> Metadata:
> AREA_OR_POINT=Area
> Image Structure Metadata:
> INTERLEAVE=PIXEL
> Corner Coordinates:
> Upper Left ( 202245.241, 421915.721) ( 35d 1'32.11"E, 29d53' 7.03"N)
> Lower Left ( 202245.241, 418790.721) ( 35d 1'32.29"E, 29d51'25.54"N)
> Upper Right ( 205370.241, 421915.721) ( 35d 3'28.57"E, 29d53' 7.17"N)
> Lower Right ( 205370.241, 418790.721) ( 35d 3'28.72"E, 29d51'25.68"N)
> Band 1 Block=25000x1 Type=Byte, ColorInterp=Red
> Band 2 Block=25000x1 Type=Byte, ColorInterp=Green
> Band 3 Block=25000x1 Type=Byte, ColorInterp=Blue
> Band 4 Block=25000x1 Type=Byte, ColorInterp=Undefined
> and the listgeo output is also different:
> listgeo HiBar_21022022_A1b.tif
> Version: 1
> Key_Revision: 1.0
> Tagged_Information:
> 0 0 0
> 0.125 0.125 0
> End_Of_Tags.
> Keyed_Information:
> GTCitationGeoKey (Ascii,30): "Israel 1993 / Israeli TM Grid"
> GeogCitationGeoKey (Ascii,12): "Israel 1993"
> TM Grid)
> End_Of_Keys.
> End_Of_Geotiff.
> Corner Coordinates:
> 7.03"N)
> 29d51'25.54"N)
> 7.17"N)
> 29d51'25.68"N)
> So I guess that solves the problem, allowing for reprojection, and
> mapping together with other datasets.
> Thanks for you help (spot on, as always!)
>> You likely need to gdal_translate -a_srs EPSG:2039 to do something
>> useful with that file, and report to the data producer that the CRS
>> encoding is broken
>> Le 08/03/2023 à 13:18, Micha Silver a écrit :
>>> Hi Even:
>>> Here's the full gdalinfo, with the reported CRS:
>>> gdalinfo HiBar_21022022_A1.tif
>>> Files: HiBar_21022022_A1.tif
>>> HiBar_21022022_A1.tif.aux.xml
>>> BASEGEOGCRS["WGS 84",
>>> DATUM["World Geodetic System 1984",
>>> ELLIPSOID["WGS 84",6378137,298.257223563,
>>> LENGTHUNIT["metre",1,
>>> ID["EPSG",9001]]]],
>>> ANGLEUNIT["degree",0.0174532925199433,
>>> ID["EPSG",9122]]]],
>>> CONVERSION["unnamed",
>>> METHOD["unnamed"]],
>>> CS[Cartesian,2],
>>> AXIS["(E)",east,
>>> ORDER[1],
>>> ID["EPSG",9001]]],
>>> AXIS["(N)",north,
>>> ORDER[2],
>>> ID["EPSG",9001]]]]
>>> Metadata:
>>> AREA_OR_POINT=Area
>>> INTERLEAVE=PIXEL
>>> Corner Coordinates:
>>> and proj version:
>>> proj
>>> Rel. 9.1.1, December 1st, 2022
>>> (a newly installed debian 12)
>>> Thanks,
>>> Micha
>>> On 08/03/2023 13:47, Even Rouault wrote:
>>>> Micha,
>>>> which CRS is reported and which PROJ version do you use ? It is
>>>> presumably one projection method for which PROJ only implements the
>>>> forward conversion, that is from geographic to projected
>>>> coordinates, but not the reverse way
>>>> Even
>>>> Le 08/03/2023 à 09:37, Micha Silver a écrit :
>>>>> I received some Geotiff files, and gdalinfo shows:
>>>>> Corner Coordinates:
>>>>> Upper Left ( 205370.241, 418790.721)
>>>>> Lower Left ( 205370.241, 415665.721)
>>>>> Upper Right ( 206198.866, 418790.721)
>>>>> Lower Right ( 206198.866, 415665.721)
>>>>> Center ( 205784.553, 417228.221)
>>>>> What does that mean?
>>>>> gdalinfo --version
>>>>> GDAL 3.6.2, released 2023/01/02
>>>>> Thanks
>>>>> Micha Silver
>>>>> Remote Sensing Lab, Sde Boker
>>>>> Ben Gurion University
>>>>> +972-523-665918
>>>>> _______________________________________________
>>>>> gdal-dev mailing list
>>>>> gdal-dev at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
>>>> http://www.spatialys.com
>>>> My software is free, but my time generally not.
>>> Micha Silver
>>> +972-523-665918
> Micha Silver
> +972-523-665918
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230308/9471d84d/attachment-0001.htm>
