[gdal-dev] Reprojecting with Same Projection but Different Central_Meridians
Brad Hards
bradh at frogmouth.net
Thu Mar 16 01:14:32 PDT 2023
On Thursday, 16 March 2023 3:13:59 PM AEDT Tom Hayden wrote:
> >>> u.Transfrom(transform_func)
Did this line not give you an error?
In any case, I used:
import osgeo.osr as osr
import osgeo.ogr as ogr
p = 'PROJCS["WGS_1984_Web_Mercator_Auxiliary_Sphere",GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Mercator_Auxiliary_Sphere"],PARAMETER["False_Easting",0.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",-41.34804059746178],PARAMETER["Standard_Parallel_1",0.0],PARAMETER["Auxiliary_Sphere_Type",0.0],UNIT["Meter",1.0]]'
p2 = """PROJCS["WGS_1984_Web_Mercator_Auxiliary_Sphere",GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Mercator_Auxiliary_Sphere"],PARAMETER["False_Easting",0.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",0.0],PARAMETER["Standard_Parallel_1",0.0],PARAMETER["Auxiliary_Sphere_Type",0.0],UNIT["Meter",1.0]]"""
srs2 = osr.SpatialReference(wkt=p2)
srs = osr.SpatialReference(wkt=p)
transform_func = osr.CoordinateTransformation(srs2, srs)
u = ogr.Geometry(ogr.wkbPoint)
u.AddPoint(0,0)
u.Transform(transform_func)
print(u.ExportToWkt())
which resulted in:
POINT (4602842.82460905 0.0 0)
Brad
