[gdal-dev] Reprojecting with Same Projection but Different Central_Meridians
Tom Hayden
thayden at gmail.com
Thu Mar 16 05:49:25 PDT 2023
You guys are the best - thank you. I thought I was going crazy. Brad - your
code worked great on version 3.6.0 but when I was running this locally on
3.0.4. I get the wrong answer at the end. No problem, though, because this
is fixed now. Thank you!!
>>> transform_func = osr.CoordinateTransformation(srs2, srs)
>>> u = ogr.Geometry(ogr.wkbPoint)
>>> u.AddPoint(0,0)
>>> u.Transform(transform_func)
0
>>> print(u.ExportToWkt())
POINT (0 0 0)
>>> import osgeo
>>> osgeo.__version__
'3.0.4'
Meanwhile, works great in 3.6.0
>>> import osgeo.osr as osr
>>> import osgeo.ogr as ogr
>>> p =
'PROJCS["WGS_1984_Web_Mercator_Auxiliary_Sphere",GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Mercator_Auxiliary_Sphere"],PARAMETER["False_Easting",0.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",-41.34804059746178],PARAMETER["Standard_Parallel_1",0.0],PARAMETER["Auxiliary_Sphere_Type",0.0],UNIT["Meter",1.0]]'
>>> p2 =
"""PROJCS["WGS_1984_Web_Mercator_Auxiliary_Sphere",GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Mercator_Auxiliary_Sphere"],PARAMETER["False_Easting",0.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",0.0],PARAMETER["Standard_Parallel_1",0.0],PARAMETER["Auxiliary_Sphere_Type",0.0],UNIT["Meter",1.0]]"""
>>> srs2 = osr.SpatialReference(wkt=p2)
>>> srs = osr.SpatialReference(wkt=p)
>>> u.AddPoint(0,0)
0
POINT (4602842.82460905 0.0 0)
>>> osgeo.__version__
'3.6.0'
On Thu, Mar 16, 2023 at 3:14 AM Brad Hards <bradh at frogmouth.net> wrote:
> On Thursday, 16 March 2023 3:13:59 PM AEDT Tom Hayden wrote:
> > >>> u.Transfrom(transform_func)
> Did this line not give you an error?
> In any case, I used:
> p =
> p2 =
> u.AddPoint(0,0)
> which resulted in:
> Brad
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230316/764a497d/attachment.htm>
