[gdal-dev] Generated CMake build files missing external references
Derek Newhall dnewhall at carlsonsw.com
Thu Mar 16 12:51:03 PDT 2023
Hello,
We are trying to migrate from GDAL 3.5.1 to 3.6.3. We currently build a
custom gdal*.dll file using a modified nmake.opt file and are trying to
duplicate it as a ConfigUser.cmake file. We are building GDAL with ECW 5.5,
curl, sqlite3, pdfium, OpenSSL, and Expat.
With 3.6.3 I can get the build files to generate seemingly correctly with
our ConfigUser.cmake file and 'cmake -G "Visual Studio 16 2019" .. -C
..\ConfigUser.cmake' but the build fails once 'cmake --build .' is run.
The output of the configure step confirms everything's found, listing the
following at the end:
"-- The following OPTIONAL package have been found:" ODBC, XercesC,
OpenSSL, ECW, PDFIUM
"-- The following RECOMMENDED packages have been found:" CURL, EXPAT,
SQLite3
"-- The following REQUIRED packages have been found:" PROJ
However, once the build happens, a few projects have compilation errors
relating to external header files (specifically Xerces):
D:\gdal-3.6.3\ogr\ogr_xerces_headers.h(37,10): fatal error C1083: Cannot
open include file: 'xercesc/framework/MemoryManager.hpp': No such file or
directory [D:\gdal-3.6.3\build\gcore\gcore.vcxproj]
We are able to fix these references manually in Visual Studio by adding the
external include directories to Xerces for the following projects: gcore,
ogr, ogr_GMLAS, ogr_GML, ogr_NAS, ogr_ILI
That gets it to compile at least, but then we run into some similar linking
issues.
We're new to building the 3.6.x branch, so I'm presuming we've
misconfigured something somewhere, but I am not sure what it is in this
case.
Thank you,
Derek Newhall
The following is the contents of our ConfigUser.cmake file:
set(GDAL_BUILD_ABS_PATH "D:/gdal-3.6.3")
set(GLOBAL_LIBRARIES_ABS_PATH "D:/global_libraries")
set (CMAKE_BUILD_TYPE RelWithDebInfo CACHE STRING "" FORCE)
set(PROJ_INCLUDE_DIR "${GDAL_BUILD_ABS_PATH}/proj-6.3.1/src" CACHE STRING
"" FORCE)
set(PROJ_LIBRARY_RELEASE
"${GDAL_BUILD_ABS_PATH}/proj-6.3.1/build_VS2017_x64/lib/RelWithDebInfo/proj.lib"
set(ECW_ROOT "${GDAL_BUILD_ABS_PATH}/ERDAS ECW JPEG 2000 SDK 5.5.0/Desktop
Read-Only")
set(ECW_INCLUDE_DIR "${ECW_ROOT}/include" CACHE STRING "" FORCE)
set(ECW_LIBRARY "${ECW_ROOT}/lib/vc141/x64/NCSEcwS.lib" CACHE STRING ""
FORCE)
set(XERCES_DIR "${GLOBAL_LIBRARIES_ABS_PATH}/xerces-c-3.2.1/build/2017/"
set(XercesC_INCLUDE_DIR "${XERCES_DIR}/src/" CACHE STRING "" FORCE)
set(XercesC_LIBRARY "${XERCES_DIR}/src/Release/xerces-c_3.lib" CACHE STRING
"" FORCE)
set(SQLite3_INCLUDE_DIR
"${GDAL_BUILD_ABS_PATH}/sqlite-amalgamation-3370200" CACHE STRING "" FORCE)
set(SQLite3_LIBRARY
"${GDAL_BUILD_ABS_PATH}/sqlite-amalgamation-3370200/sqlite3.lib" CACHE
STRING "" FORCE)
set(CURL_DIR "${GDAL_BUILD_ABS_PATH}/libcurl" CACHE STRING "" FORCE)
set(CURL_INCLUDE_DIR "${CURL_DIR}/include" CACHE STRING "" FORCE)
set(CURL_LIBRARY_RELEASE "${CURL_DIR}/lib/libcurl.lib" CACHE STRING ""
FORCE)
set(PDFIUM_INCLUDE_DIR
"${GDAL_BUILD_ABS_PATH}/ExtractPDFium/install/include/pdfium" CACHE STRING
"" FORCE)
set(PDFIUM_LIBRARY
"${GDAL_BUILD_ABS_PATH}/ExtractPDFium/install/lib/pdfium.lib" CACHE STRING
"" FORCE)
set(GDAL_ENABLE_DRIVER_PDF_PLUGIN ON)
set(OPENSSL_ROOT_DIR "${GLOBAL_LIBRARIES_ABS_PATH}/openssl-1.1.0f-vs2017"
set(OPENSSL_INCLUDE_DIR "${OPENSSL_ROOT_DIR}/include64" CACHE STRING ""
FORCE)
set(OPENSSL_USE_STATIC_LIBS TRUE CACHE STRING "" FORCE)
set(OPENSSL_MSVC_STATIC_RT TRUE CACHE STRING "" FORCE)
set(EXPAT_DIR "${GDAL_BUILD_ABS_PATH}/Expat/" CACHE STRING "" FORCE)
set(EXPAT_INCLUDE_DIR "${GDAL_BUILD_ABS_PATH}/Expat/Source/lib" CACHE
STRING "" FORCE)
set(EXPAT_LIBRARY "${GDAL_BUILD_ABS_PATH}/Expat/Bin/libexpatwMT.lib" CACHE
STRING "" FORCE)
Disclaimer
The information contained in this communication from the sender is confidential. It is intended solely for use by the recipient and others authorized to receive it. If you are not the recipient, you are hereby notified that any disclosure, copying, distribution or taking action in relation of the contents of this information is strictly prohibited and may be unlawful.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230316/c418df74/attachment.htm>
