[gdal-dev] Python bindings: enabling exceptions by default?
Kurt Schwehr
schwehr at gmail.com
Mon Mar 20 13:07:31 PDT 2023
We are heavy users of the swig bindings. We have some Fiona users and are
only just now in the process of starting to use rasterio. We have only 3
instances of calling UseExceptions. Turning on UseExceptions
immediately blew up a bunch of my tests that were making incorrect
assumptions. Nothing major, but I haven't looked for more than a couple
seconds for trouble.
+1 for switching to have it enabled by default. I'm not sure if it would be
better with 3.7.0 or 4.0.0.
On Mon, Mar 20, 2023 at 10:58 AM Howard Butler <howard at hobu.co> wrote:
> > On Mar 19, 2023, at 7:34 AM, Even Rouault <even.rouault at spatialys.com>
> wrote:
> > Hi,
> > I've prepared a pull request that does the above, but this raises a
> number of questions. See my longish comment at
> https://github.com/OSGeo/gdal/pull/7475#issuecomment-1475239852. Thoughts
> appreciated
> First off, thank you for doing this.
> Speaking for myself, pretty much all of the ogr.py/gdal.py code I've
> written for the past 15 years has gdal.UseExceptions() after the "from
> osgeo import gdal" import. The reasons why we had to have this 15 years ago
> were reasonable, but now it is just confusing boilerplate. It's time to
> ditch it.
> It has been a regret that we didn't clean up the secondary effects of
> UseExceptions/DontUseExceptions a long time ago. I'm sure the original sin
> was a result of my mucking with the SWIG bindings to get something that
> kind of worked and giving up after that. I'm glad your PR addresses this
> and makes things better for other handler-aware code that is often mixed
> together with gdal.py such as Fiona/rasterio, QGIS bindings, or PDAL stuff
> (in my case).
> As for enabling them by default at our next 3.7 release ... one one hand,
> it has been fifteen years already and the project has been telegraphing
> through the options that this could/should change. On the other, GDAL is
> *very* conservative with API evolution, and making UseExceptions default
> behavior in the Python bindings breaks existing code that wasn't doing
> gdal.UseExceptions already. The nice thing about activating this behavior
> is that it causes it to throw an exception and tell the user about
> something that was otherwise silently failing, so the remedy in the case of
> most of these breakages is going to be clear.
> I would vote that we go for enabling UseExceptions by default for GDAL 3.7
> based on the following assumptions:
> * The group that will feel the largest impact by the change is GDAL's own
> autotest suite
> * Exceptions are the Python Way, and default behavior of GDAL's bindings
> is out of step
> * Tons of user-land code is already doing UseExceptions, as it is a
> practice that is recommended in many tutorials and books and SE posts
> * The largest portion of GDAL-using Python developers are using Rasterio
> or Fiona, not gdal.py and ogr.py, and they would not be impacted by these
> changes (and maybe be impacted positively as the ticket describes).
> Are you a GDAL Python bindings user? Would you be impacted by this policy
> change? Please chime in.
> Howard
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230320/a02397de/attachment.htm>
