[gdal-dev] GDAL does not get correct GCPs from ESRI GeodataXform
Even Rouault
even.rouault at spatialys.com
Mon Mar 20 14:29:40 PDT 2023
Filed as https://github.com/OSGeo/gdal/issues/7484 : At first sight the
issue is that file uses TIFFTAG_RESOLUTIONUNIT=3 (pixels/cm), whereas
the current code only deals with TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
Le 20/03/2023 à 22:09, Rahkonen Jukka a écrit :
> Hi,
> I noticed this question in gis.stackexchange
> https://gis.stackexchange.com/questions/455609/warping-arcgis-9-2-georeferenced-tiffs-using-gdal-warp.
> It seems that GDAL cannot interpret right the ground control points
> which are stored into the aux.xml file. I can see that the support for
> GeodataXform has been improved a few times
> https://github.com/OSGeo/gdal/search?q=geodataxform&type=commits
> <https://github.com/OSGeo/gdal/search?q=geodataxform&type=commits> but
> maybe this dataset (there is a link for downloading test data) has
> some previously untested sort of aux.xml. The GeoTIFF has wrong GCPs
> with small pixel values like (16.5886813769484,11.2421187314794) but I
> made also a test with “--config GDAL_GEOREF_SOURCES PAM” and even by
> creating a cleaned baseline tiff + PAM file but the GCPs looked still
> wrong.
> -Jukka Rahkonen-
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230320/089f6720/attachment.htm>
