[gdal-dev] GDAL sponsored maintenance report: Aug 2021-March 2023
Even Rouault
even.rouault at spatialys.com
Mon Mar 27 09:35:25 PDT 2023
After more than one year and a half of benefiting from the GDAL
sponsored maintenance program, it is time to share with the community
what work has been accomplished thanks to that sponsorship. It is quite
hard to summarize, as the amount of tasks reaches 1800 for a total of
1313 hours. So lots of small tasks that make the daily reality of
maintaining a project like GDAL.
Their global repartition is the following one:
Bug fixing: 51% of actions, 55% of time spent (including 177 bug
fixes related to issues found by oss-fuzz)
Enhancements: 5% of actions, 15% of time spent
CMake related work: 5% of actions, 10% of time spent
Review of contributions: 20% of actions, 5% of time spent
Release management: 2% of actions, 4% of time spent
Bug triaging and analysis (without corresponding bug fix): 8% of
actions, 3% of time spent
Maintenance of continuous integration setup: 3% of actions and time
spent
Code enhancements/cleanups: 2% of actions and time spent
Documentation: 1% of actions and time spent
Other activities: mailing list discussions, bug reports to other
projects, meetings, etc.
This work has benefited mostly to GDAL (80%), PROJ (15%), libtiff (2%),
openjpeg (1%) and more marginally to other projects associated with GDAL
such as Xerces-C, poppler, libgeotiff, cppcheck, netcdf, curl, libjxl
and shapelib.
The CMake related work has been a major item of work for the mid 2021 -
beginning of 2022 period. I cannot overstate the importance of the
initial contribution of this work made by Hiroshi Miura who brought most
of the initial material. That said, without the sponsored maintenance
program which helped polishing and making it production ready for all
environments supported by GDAL, this would likely have remained a
out-of-tree project. I believe most stakeholders (contributors and
users, at least the ones who build from source) are very satisfied with
this transition from the historic build systems to a unified and more
modern one, with consistent option naming. Building on Windows is in
particular much easier nowadays, in particular when leveraging
dependencies from distributions like vcpkg or Conda Forge. For GDAL
developers, the new build system offers integration with IDEs and solves
long standing annoyances like missing header dependency rules for
partial rebuilds.
Although it doesn’t show up particularly in the above statistics, making
sure that the continuous integration configurations remain “green” at
all times is a constant source of attention. Given the number of
environments tested and the number of dependencies of GDAL, there is
hardly a week where some action is not needed in that area to make sure
that the code builds and compiles cleanly, tests pass, etc. We can now
track a few rolling distributions to detect as early as possible sources
of incompatibilities with our dependencies, and act early: report issues
to upstream if there are bugs, or do changes in our code & build scripts
to take them into account.
Making sure that code contributions from others are reviewed in a timely
manner is important for the contributor experience. The average delay
for a submitted pull request (excluding mine) to be commented by me (or
merged if no comment needed) is 22 hours, and the median time 3h20
(statistics gathered on 601 pull requests since August 2021, source
script at https://gist.github.com/rouault/0fbd37f59b8e93ae63761468a5600262)
In the category of regular tasks, one can also mention: updating the
EPSG dataset in PROJ (and coordinating with IOGP when detecting issues),
refreshing vendored of copies in the GDAL source tree (libtiff
typically), making sure that new SQLite releases play nicely with PROJ
which has some stressing SQL queries (we spot recently a performance
regression in SQLite 3.41.0 and reported it to upstream)
The following RFCs have been implemented (not mentioning a few
procedural ones) thanks to the sponsorship:
RFC 87: Signed int8 data type for raster
<https://gdal.org/development/rfc/rfc87_signed_int8.html>
RFC 88: Use GoogleTest framework for C/C++ unit tests
<https://gdal.org/development/rfc/rfc88_googletest.html>
RFC 90: Direct access to compressed raster data
<https://gdal.org/development/rfc/rfc90_read_compressed_data.html>
RFC 91: GDALDataset::Close() method
<https://gdal.org/development/rfc/rfc91_dataset_close.html>
RFC 93: OGRLayer::UpdateFeature() method
<https://gdal.org/development/rfc/rfc93_update_feature.html>
Other recent significant work includes enhancements in Python exception
handling (in preparation for enabling them by default in a future 4.0
release), and enabling them in the regression test suite and utilities.
The following feature releases have been issued: 3.4.0, 3.5.0 and 3.6.0.
And the following bug fixes releases: 3.3.2, 3.3.3, 3.4.1, 3.4.2, 3.4.3,
3.5.1, 3.5.2, 3.6.1, 3.6.2 and 3.6.3
Best regards,
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230327/0299c1eb/attachment.htm>
