[gdal-dev] GDAL sponsored maintenance report: Aug 2021-March 2023
Tamas Szekeres
szekerest at gmail.com
Mon Mar 27 13:40:51 PDT 2023
Hi Even,
Thank you for your hard work to keep GDAL running at a high intensity and
quality level, which also shows well in the openhub stats:
https://openhub.net/p/gdal/contributors?sort=latest_commit&time_span=12+months
Keep up the good work :-)
Best regards,
Tamas
Even Rouault <even.rouault at spatialys.com> ezt írta (időpont: 2023. márc.
27., H, 18:35):
> Hi,
> After more than one year and a half of benefiting from the GDAL sponsored
> maintenance program, it is time to share with the community what work has
> been accomplished thanks to that sponsorship. It is quite hard to
> summarize, as the amount of tasks reaches 1800 for a total of 1313 hours.
> So lots of small tasks that make the daily reality of maintaining a project
> like GDAL.
> Their global repartition is the following one:
> Bug fixing: 51% of actions, 55% of time spent (including 177 bug fixes
> related to issues found by oss-fuzz)
> Enhancements: 5% of actions, 15% of time spent
> CMake related work: 5% of actions, 10% of time spent
> Review of contributions: 20% of actions, 5% of time spent
> Release management: 2% of actions, 4% of time spent
> Bug triaging and analysis (without corresponding bug fix): 8% of
> actions, 3% of time spent
> Maintenance of continuous integration setup: 3% of actions and time
> spent
> Code enhancements/cleanups: 2% of actions and time spent
> Documentation: 1% of actions and time spent
> Other activities: mailing list discussions, bug reports to other
> projects, meetings, etc.
> This work has benefited mostly to GDAL (80%), PROJ (15%), libtiff (2%),
> openjpeg (1%) and more marginally to other projects associated with GDAL
> such as Xerces-C, poppler, libgeotiff, cppcheck, netcdf, curl, libjxl and
> shapelib.
> The CMake related work has been a major item of work for the mid 2021 -
> beginning of 2022 period. I cannot overstate the importance of the initial
> contribution of this work made by Hiroshi Miura who brought most of the
> initial material. That said, without the sponsored maintenance program
> which helped polishing and making it production ready for all environments
> supported by GDAL, this would likely have remained a out-of-tree project. I
> believe most stakeholders (contributors and users, at least the ones who
> build from source) are very satisfied with this transition from the
> historic build systems to a unified and more modern one, with consistent
> option naming. Building on Windows is in particular much easier nowadays,
> in particular when leveraging dependencies from distributions like vcpkg or
> Conda Forge. For GDAL developers, the new build system offers integration
> with IDEs and solves long standing annoyances like missing header
> dependency rules for partial rebuilds.
> Although it doesn’t show up particularly in the above statistics, making
> sure that the continuous integration configurations remain “green” at all
> times is a constant source of attention. Given the number of environments
> tested and the number of dependencies of GDAL, there is hardly a week where
> some action is not needed in that area to make sure that the code builds
> and compiles cleanly, tests pass, etc. We can now track a few rolling
> distributions to detect as early as possible sources of incompatibilities
> with our dependencies, and act early: report issues to upstream if there
> are bugs, or do changes in our code & build scripts to take them into
> account.
> Making sure that code contributions from others are reviewed in a timely
> manner is important for the contributor experience. The average delay for a
> submitted pull request (excluding mine) to be commented by me (or merged if
> no comment needed) is 22 hours, and the median time 3h20 (statistics
> gathered on 601 pull requests since August 2021, source script at
> https://gist.github.com/rouault/0fbd37f59b8e93ae63761468a5600262)
> In the category of regular tasks, one can also mention: updating the EPSG
> dataset in PROJ (and coordinating with IOGP when detecting issues),
> refreshing vendored of copies in the GDAL source tree (libtiff typically),
> making sure that new SQLite releases play nicely with PROJ which has some
> stressing SQL queries (we spot recently a performance regression in SQLite
> 3.41.0 and reported it to upstream)
> The following RFCs have been implemented (not mentioning a few procedural
> ones) thanks to the sponsorship:
> RFC 87: Signed int8 data type for raster
> <https://gdal.org/development/rfc/rfc87_signed_int8.html>
> RFC 88: Use GoogleTest framework for C/C++ unit tests
> <https://gdal.org/development/rfc/rfc88_googletest.html>
> RFC 90: Direct access to compressed raster data
> <https://gdal.org/development/rfc/rfc90_read_compressed_data.html>
> RFC 91: GDALDataset::Close() method
> <https://gdal.org/development/rfc/rfc91_dataset_close.html>
> RFC 93: OGRLayer::UpdateFeature() method
> <https://gdal.org/development/rfc/rfc93_update_feature.html>
> Other recent significant work includes enhancements in Python exception
> handling (in preparation for enabling them by default in a future 4.0
> release), and enabling them in the regression test suite and utilities.
> The following feature releases have been issued: 3.4.0, 3.5.0 and 3.6.0.
> And the following bug fixes releases: 3.3.2, 3.3.3, 3.4.1, 3.4.2, 3.4.3,
> 3.5.1, 3.5.2, 3.6.1, 3.6.2 and 3.6.3
> Best regards,
> Even
> -- http://www.spatialys.com
> My software is free, but my time generally not.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230327/6dfd47a7/attachment-0001.htm>
