[gdal-dev] GDAL Docker Build fails
Dirk Stenger
stenger at lat-lon.de
Tue Mar 28 12:11:44 PDT 2023
All,
Currently, the GDAL Docker Build fails:
/~/git/gdal$ docker/ubuntu-full/build.sh --platform linux/amd64//
// ---> Running in c13d037d7761//
//Downloading cache...//
//rsync: [sender] change_dir "osgeo/gdal:ubuntu-full/proj/x86_64" (in
gdal-docker-cache) failed: No such file or directory (2)//
//rsync error: some files/attrs were not transferred (see previous
errors) (code 23) at main.c(1865) [Receiver=3.2.7]//
//rsync: [Receiver] read error: Connection reset by peer (104)//
//The command '/bin/sh -c . /buildscripts/bh-set-envvars.sh &&
DESTDIR=/build_tmp_proj /buildscripts/bh-proj.sh &&
LD_LIBRARY_PATH=/build_tmp_proj/usr/local/lib
/build_tmp_proj/usr/local/bin/projsync --target-dir /tmp/proj_grids
--all && rm -rf /build_tmp_proj' returned a non-zero code: 23/
A couple of days ago, I was still able to build it (v3.5).
Kind regards,
Dirk Stenger
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230328/ed89f623/attachment.htm>
