[gdal-dev] GDAL Docker Build fails
Dirk Stenger stenger at lat-lon.de
Wed Mar 29 03:52:03 PDT 2023
Even,
Unfortunately, the builds still fail with the same error messages today.
I tried following setups:
- Branch: /master/; Command: /docker/ubuntu-full/build.sh --platform
linux/amd64/
- Branch: /release/3.5/; Command: /docker/ubuntu-full/build.sh
--platform linux/amd64 --gdal v3.5.3/
I am on the latest git status in both cases.
I also deleted the /gdal-docker-cache /by executing/rm -rf
~/gdal-docker-cache /but it did not solve the problem.
Regards,
Dirk
Am 28.03.23 um 22:00 schrieb Even Rouault:
> Dirk,
> Le 28/03/2023 à 21:11, Dirk Stenger a écrit :
>> All,
>> Currently, the GDAL Docker Build fails:
>> /~/git/gdal$ docker/ubuntu-full/build.sh --platform linux/amd64//
>> // ---> Running in c13d037d7761//
>> //Downloading cache...//
>> //rsync: [sender] change_dir "osgeo/gdal:ubuntu-full/proj/x86_64" (in
>> gdal-docker-cache) failed: No such file or directory (2)//
>> //rsync error: some files/attrs were not transferred (see previous
>> errors) (code 23) at main.c(1865) [Receiver=3.2.7]//
>> //rsync: [Receiver] read error: Connection reset by peer (104)//
>> //The command '/bin/sh -c . /buildscripts/bh-set-envvars.sh     &&
>> DESTDIR=/build_tmp_proj /buildscripts/bh-proj.sh  &&
>> LD_LIBRARY_PATH=/build_tmp_proj/usr/local/lib
>> /build_tmp_proj/usr/local/bin/projsync --target-dir /tmp/proj_grids
>> --all      && rm -rf /build_tmp_proj' returned a non-zero code: 23/
>> A couple of days ago, I was still able to build it (v3.5).
> Make sure you update on latest git. If you're on the 3.5 branch, I'm
> not sure its build scripts will work properly with latest master
> But given where the error occurs, I suspect this might be something
> related to downloading PROJ remote grids. There has been a new grid
> added today and the indexes refreshed. Perhaps there has been some
> out-of-sync issue with CloudFront. I suggest you just retry, a few
> times if needed (that just worked fine for me without any need for
> retry, but we might not hit the same CloudFront instances)
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
l a t / l o n  GmbH
Im Ellig 1                           53343 Wachtberg, Germany
phone ++49 +228 24 333 784
http://www.lat-lon.de                   http://www.deegree.org
lat/lon gesellschaft für raumbezogene informationssysteme mbH
Registergericht: Amtsgericht Bonn, HRB 13042
Geschäftsführer: Jens Fitzke und Torsten Friebe
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230329/1f21c26e/attachment.htm>
