[gdal-dev] Cannot find proj.db
Elena Ruiz
eruiz at aplitop.com
Thu Mar 30 05:01:30 PDT 2023
Hello,
I am using GDAL 3.6.2 on Windows 11 and am having problems with the following error:
ERROR 1: PROJ: proj_create_from_database: Cannot find proj.db
I have set as environment variable PROJ_LIB= "D:\MDT\V9\bin\gdal\gdal_latest\share" and PROJ_DATA= "D:\MDT\V9\bin\gdal\gdal_latest\share", as user variable and in the system variable, but it still doesn't work and the file proj.db exits in D:\MDT\V9\bin\gdal\gdal_latest\share .
D:\MDT\V9\bin\gdal\gdal_latest\x64>gdalwarp -s_srs EPSG:4326 -t_srs EPSG:25831 -r near -of GTiff C:\Users\elena\Downloads\D37531385_0101_DTM.asc C:/Users/elena/Downloads/D37531385_0101_DTM_25831_qgis_.tif
ERROR 1: Translating source or target SRS failed:
EPSG:4326
The funny thing is that I have the same version of GDAL installed on my computer using Anaconda3, to do tests, and from the anaconda directory it works for me, and if I look in the environment variables I don't see any path that refers to where Anaconda has the Proj.db. Is there another way to set the PROJ_LIB path besides adding an environment variable? Is there any way to know where the PROJ_LIB is looking for my version of GDAL?
C:\Users\elena\Anaconda3\envs\mygdal\Library\bin>gdalwarp -s_srs EPSG:4326 -t_srs EPSG:25831 -r near -of GTiff C:\Users\elena\Downloads\D37531385_0101_DTM.asc C:/Users/elena/Downloads/D37531385_0101_DTM_25831_qgis_.tif
Creating output file that is 1003P x 1201L.
Processing C:\Users\elena\Downloads\D37531385_0101_DTM.asc [1/1] : 0Using internal nodata values (e.g. -9999) for image C:\Users\elena\Downloads\D37531385_0101_DTM.asc.
Copying nodata values from source C:\Users\elena\Downloads\D37531385_0101_DTM.asc to destination C:/Users/elena/Downloads/D37531385_0101_DTM_25831_qgis_.tif.
...10...20...30...40...50...60...70...80...90...100 - done.
Thank you and regards
[https://www.aplitop.com/descargas/firma1.jpg]
Elena Ruiz
Sofware Development & Technical Support
Tel. +34 952 43 97 71
Sumatra, 9 - 29190 M?laga (Spain)
www.aplitop.com
[cid:SocialLink_Facebook_32x32_a745adb8-c250-4372-8480-e77f503dad3d.png]<https://www.facebook.com/AplitopSL/> [cid:SocialLink_Twitter_32x32_858247f6-9d4a-4740-a6b3-9b5ebfd98a97.png] <https://twitter.com/aplitop> [cid:SocialLink_Linkedin_32x32_154d63de-bf68-468f-9eb0-ffed102fac77.png] <https://www.linkedin.com/company/aplitop> [cid:SocialLink_Youtube_32x32_0dea15dd-3774-4086-be9d-f62560b70c86.png] <https://www.youtube.com/user/aplitop>
In accordance with the provisions of the European Regulation of Data Protection 2016/679 (Reglamento Europeo de Protecci?n de Datos 2016/679), we inform you that the data and the information you provide us through this medium will be used by APLITOP, S.L., with C.I.F. B-92543396 and with address at C / Sumatra, 9, Malaga, 29190, in order to answer your questions and inform you about our products. The data provided will be kept as long as it does not request its cessation and will not be transferred to third parties except in cases where there is a legal obligation. You have the right to access your personal data, correct inaccurate data or request its deletion when the data is no longer necessary for the purposes that were collected, as well as any rights recognized in the RGPD 2016/679
<https://www.aplitop.com/New/en/443/publication-of-point-clouds-on-web>
<https://www.aplitop.com/New/en/438/tcpmdt-v9-is-here><https://www.aplitop.com/Event/en/429/aplitop-at-intergeo-2022-essen>
<https://www.aplitop.com/Event/en/358/intergeo-2019>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230330/d9258761/attachment.htm>
Type: image/png
Desc: SocialLink_Facebook_32x32_a745adb8-c250-4372-8480-e77f503dad3d.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230330/d9258761/attachment.png>
Type: image/png
Desc: SocialLink_Twitter_32x32_858247f6-9d4a-4740-a6b3-9b5ebfd98a97.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230330/d9258761/attachment-0001.png>
Type: image/png
Desc: SocialLink_Linkedin_32x32_154d63de-bf68-468f-9eb0-ffed102fac77.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230330/d9258761/attachment-0002.png>
Type: image/png
Desc: SocialLink_Youtube_32x32_0dea15dd-3774-4086-be9d-f62560b70c86.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230330/d9258761/attachment-0003.png>
