[gdal-dev] Cannot find proj.db
Thomas Knudsen
knudsen.thomas at gmail.com
Thu Mar 30 10:47:36 PDT 2023
Elena,
If your environment variables are set exactly as you write:
> PROJ_LIB= “D:\MDT\V9\bin\gdal\gdal_latest\share”
> PROJ_DATA= “D:\MDT\V9\bin\gdal\gdal_latest\share”
you should leave out the apostrophes and the extra space after the equals
sign, i.e.
set PROJ_LIB=D:\MDT\V9\bin\gdal\gdal_latest\share
set PROJ_DATA=D:\MDT\V9\bin\gdal\gdal_latest\share
The PROJ documentation on the subject is over at
https://proj.org/usage/environmentvars.html
/Thomas
Den tors. 30. mar. 2023 kl. 14.01 skrev Elena Ruiz <eruiz at aplitop.com>:
> Hello,
> I am using GDAL 3.6.2 on Windows 11 and am having problems with the
> following error:
> ERROR 1: PROJ: proj_create_from_database: Cannot find proj.db
> I have set as environment variable PROJ_LIB=
> “D:\MDT\V9\bin\gdal\gdal_latest\share” and PROJ_DATA=
> “D:\MDT\V9\bin\gdal\gdal_latest\share”, as user variable and in the system
> variable, but it still doesn't work and the file proj.db exits in
> D:\MDT\V9\bin\gdal\gdal_latest\share .
> D:\MDT\V9\bin\gdal\gdal_latest\x64>gdalwarp -s_srs EPSG:4326 -t_srs
> EPSG:25831 -r near -of GTiff
> C:\Users\elena\Downloads\D37531385_0101_DTM.asc
> C:/Users/elena/Downloads/D37531385_0101_DTM_25831_qgis_.tif
> ERROR 1: Translating source or target SRS failed:
> EPSG:4326
> The funny thing is that I have the same version of GDAL installed on my
> computer using Anaconda3, to do tests, and from the anaconda directory it
> works for me, and if I look in the environment variables I don't see any
> path that refers to where Anaconda has the Proj.db. Is there another way to
> set the PROJ_LIB path besides adding an environment variable? Is there any
> way to know where the PROJ_LIB is looking for my version of GDAL?
> C:\Users\elena\Anaconda3\envs\mygdal\Library\bin>gdalwarp -s_srs EPSG:4326
> -t_srs EPSG:25831 -r near -of GTiff
> Creating output file that is 1003P x 1201L.
> Processing C:\Users\elena\Downloads\D37531385_0101_DTM.asc [1/1] : 0Using
> internal nodata values (e.g. -9999) for image
> C:\Users\elena\Downloads\D37531385_0101_DTM.asc.
> Copying nodata values from source
> C:\Users\elena\Downloads\D37531385_0101_DTM.asc to destination
> C:/Users/elena/Downloads/D37531385_0101_DTM_25831_qgis_.tif.
> ...10...20...30...40...50...60...70...80...90...100 - done.
> Thank you and regards
> *Elena Ruiz *
> Sofware Development & Technical Support
> Tel. +34 952 43 97 71
> Sumatra, 9 - 29190 Málaga (Spain)
> *www.aplitop.com <http://www.aplitop.com>
> <https://www.facebook.com/AplitopSL/> <https://twitter.com/aplitop>
> <https://www.linkedin.com/company/aplitop>
> <https://www.youtube.com/user/aplitop>*
> In accordance with the provisions of the European Regulation of Data
> Protection 2016/679 (Reglamento Europeo de Protección de Datos 2016/679),
> we inform you that the data and the information you provide us through this
> medium will be used by APLITOP, S.L., with C.I.F. B-92543396 and with
> address at C / Sumatra, 9, Malaga, 29190, in order to answer your questions
> and inform you about our products. The data provided will be kept as long
> as it does not request its cessation and will not be transferred to third
> parties except in cases where there is a legal obligation. You have the
> right to access your personal data, correct inaccurate data or request its
> deletion when the data is no longer necessary for the purposes that were
> collected, as well as any rights recognized in the RGPD 2016/679
> <https://www.aplitop.com/New/en/443/publication-of-point-clouds-on-web>
> <https://www.aplitop.com/New/en/438/tcpmdt-v9-is-here>
> <https://www.aplitop.com/Event/en/429/aplitop-at-intergeo-2022-essen>
> <https://www.aplitop.com/Event/en/358/intergeo-2019>
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230330/e8b729cd/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230330/e8b729cd/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230330/e8b729cd/attachment-0001.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230330/e8b729cd/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230330/e8b729cd/attachment-0003.png>
