[gdal-dev] Data corruption when using OpenFileGDB writing and SetFeature()
Even Rouault
even.rouault at spatialys.com
Thu Mar 30 13:30:23 PDT 2023
just to notify that we have had recently a few reports of users using
the write side of the OpenFileGDB driver, and SetFeature() to update
existing features.
This proved to cause data corruptions in some situations, sometimes with
an error message on re-reading or when regenerating the spatial index,
but not always. The same could also likely happen with DeleteFeature() +
CreateFeature() scenarios, basically all situations where the driver
tries to re-use a freed space by using the .freelist file where free
spaces are recorded.
Creation of a new file or appending to a file whose features have never
been edited or deleted is OK though. You may also workaround the bug by
doing one SetFeature() operation at a time, closing the dataset, and
deleting the .freelist files in the .gdb directory, before re-opening
and doing the next edition, but that's likely to be unpractical &
inefficient.
The bug has now been fixed in master and 3.6 branches, but affects 3.6.0
to 3.6.3 releases. I'll issue a 3.6.4 in ~2 weeks.
Even
http://www.spatialys.com
