[gdal-dev] Noise at the top of NOAA19 (L1B) image
Francisco Vicent franciscovicent at outlook.com
Tue Aug 20 14:05:06 PDT 2024
Hello there, GDAL community!
I'm experiencing some issues while warping a NOAA 19 image. I'm running
a simple:
gdalwarp NSS.LHRR.NP.D16020.S1834.E1846.B3581920.WI warped.tif
When I display the result in QGIS, it seems that the image is a little
cropped and has some noise at the top:
https://imgur.com/a/gZW6Sya
I've also tried with NOAA 14 and 16 datasets and they look as expected,
so I guess that the NOAA-19 format might not be fully supported.
Anyway, I would like to hear from you if there's something I am missing,
before filing an issue or attempting a fix.
Thanks in advance.
Regards,
Francisco
