[gdal-dev] Noise at the top of NOAA19 (L1B) image
Francisco Vicent
franciscovicent at outlook.com
Wed Aug 21 13:10:32 PDT 2024
Do you suggest the image itself might be corrupt?
I can see the top of the image without noise if I extract the individual
bands using pygac and then I create a TCI with GDAL:
https://i.imgur.com/OspvQi7.png
El 21/8/2024 a las 10:49, Andrew Brooks escribió:
> That's completely normal for data which has been received from
> satellites that do not have on-board error detection/correction such
> as NOAA-n (n<20)
> On Tue, 20 Aug 2024 at 22:05, Francisco Vicent via gdal-dev
> <gdal-dev at lists.osgeo.org> wrote:
> Hello there, GDAL community!
> I'm experiencing some issues while warping a NOAA 19 image. I'm
> running
> a simple:
> gdalwarp NSS.LHRR.NP.D16020.S1834.E1846.B3581920.WI warped.tif
> When I display the result in QGIS, it seems that the image is a
> little
> cropped and has some noise at the top:
> https://imgur.com/a/gZW6Sya
> I've also tried with NOAA 14 and 16 datasets and they look as
> expected,
> so I guess that the NOAA-19 format might not be fully supported.
> Anyway, I would like to hear from you if there's something I am
> missing,
> before filing an issue or attempting a fix.
> Thanks in advance.
> Regards,
> Francisco
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240821/41f6645d/attachment.htm>
