[gdal-dev] Noise at the top of NOAA19 (L1B) image
Andrew Brooks
arb at sat.dundee.ac.uk
Fri Aug 23 08:22:48 PDT 2024
Yes, the raw data is likely corrupt. When you see the "image without noise"
pygac is probably automatically cropping off the noise for you.
On Wed, 21 Aug 2024 at 21:10, Francisco Vicent <franciscovicent at outlook.com>
wrote:
> Do you suggest the image itself might be corrupt?
> I can see the top of the image without noise if I extract the individual
> bands using pygac and then I create a TCI with GDAL:
> https://i.imgur.com/OspvQi7.png
> El 21/8/2024 a las 10:49, Andrew Brooks escribió:
> That's completely normal for data which has been received from satellites
> that do not have on-board error detection/correction such as NOAA-n (n<20)
> On Tue, 20 Aug 2024 at 22:05, Francisco Vicent via gdal-dev <
> gdal-dev at lists.osgeo.org> wrote:
>> Hello there, GDAL community!
>> I'm experiencing some issues while warping a NOAA 19 image. I'm running
>> a simple:
>> gdalwarp NSS.LHRR.NP.D16020.S1834.E1846.B3581920.WI warped.tif
>> When I display the result in QGIS, it seems that the image is a little
>> cropped and has some noise at the top:
>> https://imgur.com/a/gZW6Sya
>> I've also tried with NOAA 14 and 16 datasets and they look as expected,
>> so I guess that the NOAA-19 format might not be fully supported.
>> Anyway, I would like to hear from you if there's something I am missing,
>> before filing an issue or attempting a fix.
>> Thanks in advance.
>> Regards,
>> Francisco
>> gdal-dev mailing list
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240823/6d1b1eb5/attachment.htm>
