[gdal-dev] Noise at the top of NOAA19 (L1B) image
Francisco Vicent
franciscovicent at outlook.com
Fri Aug 23 12:27:59 PDT 2024
I understand.
Thanks for your help!
El 23/8/2024 a las 12:22, Andrew Brooks escribió:
> Yes, the raw data is likely corrupt. When you see the "image without
> noise" pygac is probably automatically cropping off the noise for you.
> On Wed, 21 Aug 2024 at 21:10, Francisco Vicent
> <franciscovicent at outlook.com> wrote:
> Do you suggest the image itself might be corrupt?
> I can see the top of the image without noise if I extract the
> individual bands using pygac and then I create a TCI with GDAL:
> https://i.imgur.com/OspvQi7.png
> El 21/8/2024 a las 10:49, Andrew Brooks escribió:
>> That's completely normal for data which has been received from
>> satellites that do not have on-board error detection/correction
>> such as NOAA-n (n<20)
>> On Tue, 20 Aug 2024 at 22:05, Francisco Vicent via gdal-dev
>> <gdal-dev at lists.osgeo.org> wrote:
>> Hello there, GDAL community!
>> I'm experiencing some issues while warping a NOAA 19 image.
>> I'm running
>> a simple:
>> gdalwarp NSS.LHRR.NP.D16020.S1834.E1846.B3581920.WI warped.tif
>> When I display the result in QGIS, it seems that the image is
>> a little
>> cropped and has some noise at the top:
>> https://imgur.com/a/gZW6Sya
>> I've also tried with NOAA 14 and 16 datasets and they look as
>> expected,
>> so I guess that the NOAA-19 format might not be fully supported.
>> Anyway, I would like to hear from you if there's something I
>> am missing,
>> before filing an issue or attempting a fix.
>> Thanks in advance.
>> Regards,
>> Francisco
>> gdal-dev mailing list
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240823/e570c2b2/attachment.htm>
