[gdal-dev] GDAL WMTS detecting errors
Michał Kowalczuk
michkowalczuk at gmail.com
Wed Aug 28 07:52:22 PDT 2024
Dear GDAL friends,
any thoughts on this issue?
Regards,
Michał
wt., 27 sie 2024 o 17:40 Michał Kowalczuk <michkowalczuk at gmail.com>
napisał(a):
> Hi!
> I'm wondering if the last issue 10348 was fully solved.
> Try use the following WMTS server and to zoom to level 9-10, e.g. small
> island in the Mediterranean
> https://basemap.nationalmap.gov/arcgis/rest/services/USGSImageryOnly/MapServer/WMTS/1.0.0/WMTSCapabilities.xml
> For a sample tile
> https://basemap.nationalmap.gov/arcgis/rest/services/USGSImageryOnly/MapServer/WMTS/tile/1.0.0/USGSImageryOnly/default/GoogleMapsCompatible/10/392/514
> arcgis server returns error code 400.
> GDALRasterIO passes so I do not know if there was an error inside. Only
> logger gives some information, but how to detect such a situation?
> A sample logger file attached
> Kind regards,
> Michał
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240828/26e5e3a2/attachment.htm>
