[gdal-dev] GDAL WMTS detecting errors
Even Rouault
even.rouault at spatialys.com
Wed Aug 28 08:07:35 PDT 2024
If you could provide a gdal_translate command line reproducing the issue
(likely using -srcwin + -outsize or -srcwin + -ovr to select the
appropriate tile), that would make investigation easier
Le 28/08/2024 à 16:52, Michał Kowalczuk via gdal-dev a écrit :
> Dear GDAL friends,
> any thoughts on this issue?
> Regards,
> Michał
> wt., 27 sie 2024 o 17:40 Michał Kowalczuk <michkowalczuk at gmail.com>
> napisał(a):
> Hi!
> I'm wondering if the last issue 10348 was fully solved.
> Try use the following WMTS server and to zoom to level 9-10, e.g.
> small island in the Mediterranean
> https://basemap.nationalmap.gov/arcgis/rest/services/USGSImageryOnly/MapServer/WMTS/1.0.0/WMTSCapabilities.xml
> <https://basemap.nationalmap.gov/arcgis/rest/services/USGSImageryOnly/MapServer/WMTS/1.0.0/WMTSCapabilities.xml>
> For a sample tile
> https://basemap.nationalmap.gov/arcgis/rest/services/USGSImageryOnly/MapServer/WMTS/tile/1.0.0/USGSImageryOnly/default/GoogleMapsCompatible/10/392/514
> arcgis server returns error code 400.
> GDALRasterIO passes so I do not know if there was an error inside.
> Only logger gives some information, but how to detect such a
> situation?
> A sample logger file attached
> Kind regards,
> Michał
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240828/035c0fdf/attachment.htm>
