[gdal-dev] GDAL WMTS detecting errors
Michał Kowalczuk
michkowalczuk at gmail.com
Wed Aug 28 08:26:03 PDT 2024
First produces correct output
*gdal_translate -srcwin 33492026 20550638 8019970 4412002 -outsize 1576 867
"WMTS:https://basemap.nationalmap.gov/arcgis/rest/services/USGSImageryOnly/MapServer/WMTS/1.0.0/WMTSCapabilities.xml,layer=USGSImageryOnly,tilematrixset=GoogleMapsCompatible
<https://basemap.nationalmap.gov/arcgis/rest/services/USGSImageryOnly/MapServer/WMTS/1.0.0/WMTSCapabilities.xml,layer=USGSImageryOnly,tilematrixset=GoogleMapsCompatible>"
tile_ok.png*
The following for higher level fails:
*gdal_translate -srcwin 36228140 21140450 191172 105168 -outsize 1576 867
tile_error.png*
śr., 28 sie 2024 o 17:07 Even Rouault <even.rouault at spatialys.com>
napisał(a):
> If you could provide a gdal_translate command line reproducing the issue
> (likely using -srcwin + -outsize or -srcwin + -ovr to select the
> appropriate tile), that would make investigation easier
> Le 28/08/2024 à 16:52, Michał Kowalczuk via gdal-dev a écrit :
> Dear GDAL friends,
> any thoughts on this issue?
> Regards,
> Michał
> wt., 27 sie 2024 o 17:40 Michał Kowalczuk <michkowalczuk at gmail.com>
> napisał(a):
>> Hi!
>> I'm wondering if the last issue 10348 was fully solved.
>> Try use the following WMTS server and to zoom to level 9-10, e.g. small
>> island in the Mediterranean
>> For a sample tile
>> https://basemap.nationalmap.gov/arcgis/rest/services/USGSImageryOnly/MapServer/WMTS/tile/1.0.0/USGSImageryOnly/default/GoogleMapsCompatible/10/392/514
>> arcgis server returns error code 400.
>> GDALRasterIO passes so I do not know if there was an error inside. Only
>> logger gives some information, but how to detect such a situation?
>> A sample logger file attached
>> Kind regards,
>> Michał
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240828/8d527f36/attachment-0001.htm>
