[gdal-dev] GDAL WMTS detecting errors
Even Rouault
even.rouault at spatialys.com
Wed Aug 28 08:38:36 PDT 2024
Le 28/08/2024 à 17:26, Michał Kowalczuk a écrit :
> First produces correct output
> /gdal_translate -srcwin 33492026 20550638 8019970 4412002 -outsize
> 1576 867
> "WMTS:https://basemap.nationalmap.gov/arcgis/rest/services/USGSImageryOnly/MapServer/WMTS/1.0.0/WMTSCapabilities.xml,layer=USGSImageryOnly,tilematrixset=GoogleMapsCompatible"
> The following for higher level fails:
> /gdal_translate -srcwin 36228140 21140450 191172 105168 -outsize 1576
> 867
> tile_error.png/
/yes, and ? gdal_translate returns in error as expected due to the
missing tiles. If you want HTTP 400 to be silently ignored, you can do:/
/gdal_translate
tmp.wmts -of wmts/
/and edit tmp.wtms to add 400 in <ZeroBlockHttpCodes>
> śr., 28 sie 2024 o 17:07 Even Rouault <even.rouault at spatialys.com>
> napisał(a):
> If you could provide a gdal_translate command line reproducing the
> issue (likely using -srcwin + -outsize or -srcwin + -ovr to select
> the appropriate tile), that would make investigation easier
> Le 28/08/2024 à 16:52, Michał Kowalczuk via gdal-dev a écrit :
>> Dear GDAL friends,
>> any thoughts on this issue?
>> Regards,
>> Michał
>> wt., 27 sie 2024 o 17:40 Michał Kowalczuk
>> <michkowalczuk at gmail.com> napisał(a):
>> Hi!
>> I'm wondering if the last issue 10348 was fully solved.
>> Try use the following WMTS server and to zoom to level 9-10,
>> e.g. small island in the Mediterranean
>> <https://basemap.nationalmap.gov/arcgis/rest/services/USGSImageryOnly/MapServer/WMTS/1.0.0/WMTSCapabilities.xml>
>> For a sample tile
>> https://basemap.nationalmap.gov/arcgis/rest/services/USGSImageryOnly/MapServer/WMTS/tile/1.0.0/USGSImageryOnly/default/GoogleMapsCompatible/10/392/514
>> arcgis server returns error code 400.
>> GDALRasterIO passes so I do not know if there was an error
>> inside. Only logger gives some information, but how to detect
>> such a situation?
>> A sample logger file attached
>> Kind regards,
>> Michał
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240828/f34d76e6/attachment.htm>
