[gdal-dev] GDAL WMTS detecting errors
Michał Kowalczuk michkowalczuk at gmail.com
Wed Aug 28 08:41:05 PDT 2024
Yes, but if you use C API function GdalRasterDatasetIO you don’t get error.
I noticed this error only in gdal logger. How I can catch this error at
runtime in code?
W dniu śr., 28.08.2024 o 17:38 Even Rouault <even.rouault at spatialys.com>
napisał(a):
> Le 28/08/2024 à 17:26, Michał Kowalczuk a écrit :
> First produces correct output
> *gdal_translate -srcwin 33492026 20550638 8019970 4412002 -outsize 1576
> 867
> "WMTS:https://basemap.nationalmap.gov/arcgis/rest/services/USGSImageryOnly/MapServer/WMTS/1.0.0/WMTSCapabilities.xml,layer=USGSImageryOnly,tilematrixset=GoogleMapsCompatible
> <https://basemap.nationalmap.gov/arcgis/rest/services/USGSImageryOnly/MapServer/WMTS/1.0.0/WMTSCapabilities.xml,layer=USGSImageryOnly,tilematrixset=GoogleMapsCompatible>"
> tile_ok.png *
> The following for higher level fails:
> *gdal_translate -srcwin 36228140 21140450 191172 105168 -outsize 1576 867
> tile_error.png*
> *yes, and ? gdal_translate returns in error as expected due to the missing
> tiles. If you want HTTP 400 to be silently ignored, you can do:*
> *gdal_translate
> tmp.wmts -of wmts*
> *and edit tmp.wtms to add 400 in <ZeroBlockHttpCodes> *
> śr., 28 sie 2024 o 17:07 Even Rouault <even.rouault at spatialys.com>
> napisał(a):
>> If you could provide a gdal_translate command line reproducing the issue
>> (likely using -srcwin + -outsize or -srcwin + -ovr to select the
>> appropriate tile), that would make investigation easier
>> Le 28/08/2024 à 16:52, Michał Kowalczuk via gdal-dev a écrit :
>> Dear GDAL friends,
>> any thoughts on this issue?
>> Regards,
>> Michał
>> wt., 27 sie 2024 o 17:40 Michał Kowalczuk <michkowalczuk at gmail.com>
>> napisał(a):
>>> Hi!
>>> I'm wondering if the last issue 10348 was fully solved.
>>> Try use the following WMTS server and to zoom to level 9-10, e.g. small
>>> island in the Mediterranean
>>> For a sample tile
>>> https://basemap.nationalmap.gov/arcgis/rest/services/USGSImageryOnly/MapServer/WMTS/tile/1.0.0/USGSImageryOnly/default/GoogleMapsCompatible/10/392/514
>>> arcgis server returns error code 400.
>>> GDALRasterIO passes so I do not know if there was an error inside. Only
>>> logger gives some information, but how to detect such a situation?
>>> A sample logger file attached
>>> Kind regards,
>>> Michał
>> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
>> -- http://www.spatialys.com
>> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240828/519331ac/attachment.htm>
