[gdal-dev] WMTS generating GET URL problem
Michał Kowalczuk michkowalczuk at gmail.com
Fri Dec 13 04:15:51 PST 2024
Consider the following WMTS server:
*https://geoservices-urbis.irisnet.be/geoserver/gwc/service/wmts
<https://geoservices-urbis.irisnet.be/geoserver/gwc/service/wmts>*
One of the subdataset path generated by GDAL is
*WMTS:https://geoservices-urbis.irisnet.be/geoserver/gwc/service/wmts?SERVICE=WMTS&REQUEST=GetCapabilities&VERSION=1.0.0,layer=Ortho,tilematrixset=EPSG:4326
<https://geoservices-urbis.irisnet.be/geoserver/gwc/service/wmts?SERVICE=WMTS&REQUEST=GetCapabilities&VERSION=1.0.0,layer=Ortho,tilematrixset=EPSG:4326>*
When I try to download a map I notice URL issue/error.
*gdalinfo
"WMTS:https://geoservices-urbis.irisnet.be/geoserver/gwc/service/wmts?SERVICE=WMTS&REQUEST=GetCapabilities&VERSION=1.0.0,layer=Ortho,tilematrixset=EPSG:4326
<https://geoservices-urbis.irisnet.be/geoserver/gwc/service/wmts?SERVICE=WMTS&REQUEST=GetCapabilities&VERSION=1.0.0,layer=Ortho,tilematrixset=EPSG:4326>"
tile.png --debug on --config GDAL_ENABLE_WMS_CACHE NO*
from debug:
*HTTP: Requesting [1/4]
https://geoservices-urbis.irisnet.be/geowebcache/service/wmts/rest/Ortho
<https://geoservices-urbis.irisnet.be/geowebcache/service/wmts/rest/Ortho>//EPSG:4326/EPSG:4326:7/27/129?format=image/jpeg*
look at the double slash (//) chars in the above URL
When you go to service Capabilities you can find the following resource URL:
* <ResourceURL format="image/jpeg" resourceType="tile"
template="https://geoservices-urbis.irisnet.be/geowebcache/service/wmts/rest/urbisNL/
<https://geoservices-urbis.irisnet.be/geowebcache/service/wmts/rest/urbisNL/>{style}/{TileMatrixSet}/{TileMatrix}/{TileRow}/{TileCol}?format=image/jpeg"/>*
but in the layer definition *Style* tag is empty:
*<Style isDefault="true"><ows:Identifier/></Style>*
This is probably the reason that GDAL make path using an empty string and
this generate double slash chars.
If you remove redundant slash the server responses and returns a tile, the
example:
*https://geoservices-urbis.irisnet.be/geowebcache/service/wmts/rest/Ortho/EPSG:4326/EPSG:4326:14/3567/16784?format=image/jpeg
<https://geoservices-urbis.irisnet.be/geowebcache/service/wmts/rest/Ortho/EPSG:4326/EPSG:4326:14/3567/16784?format=image/jpeg>*
And the question is: is this service or GDAL bug?  :-)
Wouldn't it be a good idea for GDAL to check the URL path for correctness
before sending the request?
Regards,
Michał
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241213/b5b53b47/attachment-0001.htm>
